Re: Speed Settings for the Flex 3401
Thank you Mike, this is probably going to be my next DA since I hate it when rotation of normal DAs stops when you really need it
That's the normal progression...
I was just on the phone with a guy getting ready to buff out a 32" Motorhome. One side is in excellent condition but the side exposed to the sun is completely oxidized.
His question was which type of DA to go with. Since he has experience machine polishing and also owns a boat and a few cars I recommended the Flex 3401 because he's going to want the power when buffing out or rather chewing off all the dead, oxidized gel-coat.
This kind of project can be undertaken with the PC style tools but a direct drive, forced rotation dual action polisher is going to be a lot more effective.
We have a brand new video on using Flex Polishers that the editing was completed today, should be available in a matter of weeks.
Hi Mike, i have used my 3401 for a few times now, and every time i try keeping this beast under control, i failed miserably...
I know this machine is force rotated, but it is really taking me for a walk when im trying to use it for getting rid of swirls or just polishing....
Are there any advice that can help me get a better control of this machine?
Hold the pad flat.
If you hold the body of the tool at any type of angle so the pad is not flat you will feel the buffing pad trying to,
- Walk away from you
- Walk towards you
- Walk to the right
- Walk to the left
Besides that, stick with 7" or smaller pads. I like the new Hybrid pads and in the new video that's what we show.
Kind of goes without saying that the smaller the pad, the less leverage the pad has over ANY tool.
A great way to "feel" this difference would be to buff using a 6.5" pad and then switch to a 4" pad on the new 4" backing plate. You would instantly find that it's incredibly easy to control the Flex 3401 by switching to small 4" pad.
That same difference can be felt using 5.5" pads by using the 4 3/8" backing plate.
Also, while thin pads work best with PC style tools, they don't help or hurt when using direct drive tools like the Flex 3401 or Rotary Buffers, so when you have the option for thin or thick pads for the size you want for the Flex 3401 opt for the thicker version.
The Flex 3401 is a heck of a workhorse but it does require a little more focus than the simple PC style tools to control and use. That's the primary reason I initially gave it an "Ease of use ranking of 3" when I wrote the below article back in 2009
How to choose the right polisher for your detailing project
Of course it always helps just to be in good physical shape if you're going to buff out cars. Not saying you're not but I never know how many people are going to read this into the future.
Lol im a pretty skinny person, when i hold the 3401, it looks huge.
But anyways... i do believe the pad is flat on the paint most of the time, and it still was walking on me.
I use 6.5" pads at all times with the Flex. CCS/HT/Flat
One hand where the head is, and the other holding the body where the trigger is at
I would advice getting a different pads as I found that flat pads are really hard to control on 3401 no matter how flat you keep them (and you can't keep them flat on the entire vehicle)!!! Poorboy's VC pads make a difference, a huge one IMO .. the best pads for 3401 by far.
As mentioned above the 4" pads are breeze to control, so give it a go!
Flex 3401 & PE14
Man thats not good.
All i have are CCS,Hybird,HT pads....
And if i use a 4" pad... what's the reason for getting the 3401 >.<?
The point of being in 'good physical shape' (or at least, fair) is to be noted. From your description of self it seems you may have a little challenge with even the mild PC.
I have just moved over from the PC the amazing Flex 3401, and Wheeeeee! Man, is there a difference ,but, as was said, it is a different animal, yes "beast". What it does teach you is to 'keep the pad flat. A guage you can use is to keep glancing at how the pad flattens out under the machine as you use it. You can pick up some unevenness if its not held flat.
So I guess with the Flex, you still apply the same amount of pressure you would with a regular DA, huh?
By grambow in forum Flex Polishers
Last Post: 10-20-2017, 02:51 PM
By asap2stacks in forum Auto Detailing 101
Last Post: 09-12-2017, 04:23 AM
By lj993 in forum Product Reviews
Last Post: 10-22-2016, 06:46 AM
By VTHokie in forum Flex Polishers
Last Post: 08-21-2014, 01:07 PM
Last Post: 02-07-2012, 02:04 AM
