Oiling the Flex 3401 felt ring
How often should air tool oil be applied to the felt ring on the Flex 3401?
Re: Oiling the Flex 3401 felt ring
I do it about ever other time I do a car.
I asked Bob Eichelberg about this for a online class video we made and he suggested a drop or two any time you change the backing plate.
We show the oil and how-to in this video,
Mike Phillips demonstrates how to remove swirls and scratches using the Flex XC 3401 VRG Dual Action Orbital Polisher
On this page, Autogeek's Online Classes
Should I add oil if I am removing the backing plate to clean out the gear housing or is the original oil still good?
Did he say which type of oil to use? I have heard air tool oil. Is that correct?
So Mike what you are saying,is that once I initially apply oil to the felt ring,it doesn't need it again unless I change to a new backing plate,due to wearing out the backing plate and/or switching to a smaller BP?
Ill have to watch the video on my computer tonight. I didnt see where you stated "it shows the OIL" in the video.
$14.99 to watch a video to find out how to apply oil to a felt ring??!!!!!
From what i was told you only need to oil it one time . A few years back they had a bad batch of Backing Plates that were actually melting from the heat that comes from there area of that felt ring . They corrected the problem but we all still place some light weight oil on the felt ring better safe then sorry .
I apply a light synthetic grease to mine called Shooters Choice. This is a Teflon based grease and does not begin to degrade until temperatures exceed 350F.
By Mazo275 in forum Flex Polishers
Last Post: 12-25-2017, 09:57 PM
By rcoops77 in forum Flex Polishers
Last Post: 11-17-2015, 10:04 AM
Last Post: 10-29-2013, 10:46 AM
By Swimmer in forum Flex Polishers
Last Post: 04-28-2011, 07:18 AM
By DSGMach1 in forum Flex Polishers
Last Post: 11-12-2010, 12:40 PM
26 | 27 | 28 | 29 | 30 | 31 |
