Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Nov 2011
    Flex 3401 question
    My flex runs so hot that it melts the glue from the back of my pads. Idk what to do to fix that. Or what's causing it.
    Super Member mark58's Avatar
    Apr 2011
    Erie Pa.
    444
    Re: Flex 3401 question
    Quote Originally Posted by Hotnes2301 View Post
    First thing;
    Welcome!
    what type pads? what backing pad?
    Mark
    The heat affecting your backing plates is a result of pressure, time and the motor running at high speed. It's the nature of the beast as you can't remove any of these factors and still do the work you're doing.
    I had a couple ask me the same question at SEMA...
    Nov 2011
    It's the factory backing plate and it melts any glue off of any pads I use. It's melted my yellow foam all the way to my wool pad. And since it's been getting so hot, none of my pads want to stick to the backing plate anymore. And this is a brand new factory replacement backing plate. But the thing is it's never melted anything until recent. It gets hot where if you touch it. It'll actually burn you. Instantly
    I'll pass the link to this thread onto Flex and see what they say...
    How old is the backing plate?
    Talked to Flex and they said without seeing the tool and more information it's really hard to say what the root cause could be.
    There has to be a root cause to this issue as it's more the exception to the rule than the norm as we just don't see posts like yours on this forum or any forum.
    Can provide more information? Maybe some pictures?
    Nov 2011
    Flex 3401 question-image-jpg
    Nov 2011
    the backing plate is only maybe a month old. if that
    Nov 2011
    Flex 3401 question-photo-jpg
  10. #10
    Aug 2010
    New Jersey
    15,170
    I know there was an issue with some early 3401's that the bevel gearset in the head wasn't lubed properly and it was causing them to be noisy and run hot...perhaps that's the problem with yours?
  1. Flex 3401 maintenance question
    By Toolhead in forum Flex Polishers
    Last Post: 02-07-2018, 06:34 AM
  2. Flex 3401 heat question.
    By Jeremy1976 in forum Flex Polishers
    Last Post: 06-13-2016, 06:02 AM
  3. Question about pad usage and the flex 3401 vrg hd
    By Ncs0816 in forum Flex Polishers
    Last Post: 07-16-2013, 08:18 PM
  4. Question on where and how to sell my new flex 3401
    By Derek Short in forum Flex Polishers
    Last Post: 04-15-2012, 06:28 PM
  5. Flex XC 3401 Question
    By JoeD in forum Auto Detailing 101
    Last Post: 06-20-2009, 09:21 PM
