Re: Flex3401 vs Griot's Garage 6" ROP
IMO Flex would work better on curves or tight spots where GG polisher will stop rotating(due to forced drive)
Thats one of the main reasons I'm looking forward to the flex 3401
I have yet to stop a GG from rotating . Used one Sunday doing a demo with Bob from Griots I leaned onto the machine so hard I almost compressed the pad so the Backing plate was close to the hood and it never stopped spinning . As far as the MF system the GG would be a better machine to use . Everyone that I spoke to so far have gotten better results with a Da versus the Flex 3401 . Micro Fiber system likes slow arm movement and light pressure .
Hi Adam,
Do you think the GG 6 has more vibration than the Flex? Do you see the GG 6 taking dominance in the DA sect. with the MF DA system? Without the MF DA system what benifets does the GG 6 have over the Flex3401?
I don't want it to look wet, I want it to look Soaked!
This is a good point. On curved panels, the 3401 exceeds, bar none. On flat panels, the GG is MORE than powerful. Technique needs to be adjusted more with the GG than the 3401, IMO. However, when I use my GG with the MF system, I have yet to find the cut and finish of *anything* I've tried on the 3401, that includes Surbuf/M105. The GG EASILY works better with the MF System compared to the 3401.
Originally Posted by jimmyjam
Hi Adam,
Yes, the GG does have more vibration than the 3401, but not as bad as the PCXP. Any traditional DA is better with the MF System because the forced rotation of the 3401 causes the fibers to lay flat when polishing. This is the exact opposite of what you want with these types of pads(and surbuf). The traditional DA does a much better job of not flattening the fibers, that's why it works better with the MF system.
Here is a good expanation from Todd Helme....
Random Orbital DA's do not have a fixed rate of OPM's vs. RPM. Take any of the newer style DA's and run them at speed six (which is usually rated between 6000-6800 OPM). Press down VERY hard on the paint, to the point the pad stalls or almost stalls. If you press down just right you can get the pad to spin at a greatly slowed rate, like 1 time per minute. While the orbits will stall slightly, most of the slack/friction is taken up in the bearing of the machine. You have created a rate of 6800 (roughly) per rotation.
Forced Rotation DA's have a fixed rate. The orbit is actually driven by the rotation, so that if the rotation stalls, so does the OPM, and vice a versa. In regards to the Flex, you are correct. The Flex orbits ten times per rotation and this never changes. This is easy to verify, spin the pad 1 time around and count the orbits, it is always ten.
This means that at maximum speed the Flex is limited to 4800 OPM. (480 RPM x 10 orbits per rotation). Flex uses a 'unique' way of rating the machine, but if we are comparing apples to apples then random orbital DA's produce more OPMs and are less likely to have the OPM rate stall (since the motor is not responsible spinning the big pad).
Now with most polishing systems and with foam pads, the Flex is going to produce more cutting power because it is a forced system and correction is dependent on how fast the foam is moving across the paint. The combination of a forced, high speed rotation, and the orbital motion means you transfering more energy to the paint.
Things get flipped around a little bit when you use something like a Surbuf or Meguiar's DA microfiber system. The texure (little fingers or the microfiber tuft) of the pad makes it more efficent with the orbital motion than with a rotational motion.
When something is orbiting it is like moving your hand in tiny circles (wax on/wax off). This exposes ALL of the microfiber (or micro finger)'s sides to the paint. Since the abrasive grains in the polish attach to the microfiber, the increase in surface area (and the amount of abrasives working) means that most of polishing action is coming from the orbital motion instead of the spinning motion.
In fact too much spinning motion is a BAD thing (hence Meguiar's recommending a SLOWER speed for the DA system). This is because spinning the pad too fast will cause centrifugal force to pull the fibers outward and cause them to lay flat. Down you just have a standard sized pad vs. a pad that is using all of it's surface area (and far less abrasives are being used at a given time).
This is why many people are getting better results using random orbitals instead of forced rotation machines when using products like the Microfiber DA disks (or Surbuff's).
Hope this makes sense and clears up any confusion.
That is a good post, should help to explain why the Flex isn't the best machine for the new Meguiar's system.
Luxury Mobile Auto Detailing
Pensacola & Orlando
407.625.1480
Makes total sense and with the MF system I believe it makes non forced DAs more appealing to those in the market for one. I knw as for me my next purchase will have a GG6/MF DA system. I'm still Flex "headed" with the idea that there's no replacing the Flex, but I'm now open minded....Ha
Jimmy,
I have bot the Flex 3401 and Porter Cables 7424 so I think I'm all set for now....
By VISITOR in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
Last Post: 11-24-2017, 11:24 PM
By B00st4ddicted in forum Auto Detailing 101
Last Post: 11-29-2016, 04:51 PM
By kosoku in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 08-01-2013, 06:58 AM
By RobZ71LM7 in forum Product Reviews
Last Post: 01-17-2011, 09:31 PM
By Clutch34 in forum Off-Topic
Last Post: 01-29-2010, 05:01 AM
