suggestions for first rotory
I am currently using the PC7424xp but looking to upgrade to a rotory. I'm interested in the Flex L3403. What do you all think?
Re: suggestions for first rotory
Have you ever used a rotary before? If not,maybe you should give the 3401 a try 1st.The 3401 is going to be safer than the 3403,and it correct's very well.
Team Flex PE14-2 150(Serial#0005)/3401/3403/XFE 7-15
I think if you want it, get it!
Never used a rotory before but, can't learn without doing. How much more does the 3401 correct vs. the PC?
The 3401 isn't a rotary, it's a forced rotation DA. And it's a TOTALLY different animal to use and control than the 3403 (I own both, and both are top-notch tools). Safer yes, corrects well yes, slightly easier to use than a full-blown rotary perhaps, but the learning curve isn't the same regardless.
I would say a 3401 can do 80-85% of what a rotary can when paired with the right pad(s), product(s), and techniques. With the 3401, Surbuf pads especially will be your friend.
Don't be scared, just go easy. I love my makita but a lighter machine like the flex 3403 sparks my interest. I have the 3401 and can tell you that Flex's build quality is very good. No guts no glory Do it Do it you won't be sorry.
Thanks for the input so far guys, much appreciated. Still debating.
You are correct Shiny Lil Detlr,the 3401 is NOT a rotary.I didn't say it was.I was just giving the forum member another option.As moving from a PCXP to a rotary will take some discipline.
I think it comes down to the user's capibilities,and how well they pick something up?
But yes,THANK YOU for the correction that I did not mention (and assumed) R/TED knew that the 3401 was not a rotary.
I also have the DA and rotary,and indeed "Top Notch" tools.
BTW R/TED,I appologize I didn't mention the 3401 is a DA not a rotary.
"You are correct Shiny Lil Detlr,the 3401 is NOT a rotary.I didn't say it was.I was just giving the forum member another option.As moving from a PCXP to a rotary will take some discipline"
Op was talking about a rotary and not a DA.
"But yes,THANK YOU for the correction that I did not mention (and assumed) R/TED knew that the 3401 was not a rotary."
If the OP knew the 3401 was not a rotary, why bring it up?
"BTW R/TED,I appologize I didn't mention the 3401 is a DA not a rotary."
Thought you already assumed that.
The 3403 is a great rotary to learn with. Light weight and easy to handle.
By mbkite in forum Ask your detailing questions!
Last Post: 07-19-2015, 06:39 PM
By KB in MD in forum Rotary Buffers
Last Post: 12-21-2013, 03:19 PM
By Mike@DedicatedPerfection in forum Rotary Buffers
Last Post: 12-25-2012, 05:44 PM
By Ron in MO. in forum Auto Detailing 101
Last Post: 10-06-2011, 03:45 AM
By bgray in forum Rotary Buffers
Last Post: 09-23-2008, 05:51 PM
