Air tool oil on felt ring--Flex
I picked up some air tool oil as I read here it is recommended to lube the felt ring a little. My question is how much is necessary? A few drops around it? Say 5 or 6 drops spaced out? Or should I do a very light, thin bead around the entire ring?
Thanks.
Re: Air tool oil on felt ring--Flex
Thanks.
For best results, make sure that the entire ring is coated. This will help ensure that you get maximum life from the backing plate.
Thanks Dwayne.
Now I just need to get some time so I can start playing.
Hello. How often should the felt ring be oiled? Everytime we use it or .....?
By Toolhead in forum Flex Polishers
Last Post: 04-14-2017, 06:22 AM
Last Post: 10-29-2013, 10:46 AM
By top banana in forum Flex Polishers
Last Post: 04-19-2012, 05:59 PM
By Swimmer in forum Flex Polishers
Last Post: 04-28-2011, 07:18 AM
By Phalcon51 in forum Flex Polishers
Last Post: 12-19-2009, 10:56 AM
