Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
  1. #21
    Super Member Superdutytd's Avatar
    Apr 2009
    247
    Re: Flex L3403 Lightweight short review
    So why doesn't everyone use this lightweight machine? WHy do they sell both?
    2007 Mustang GT 5-Speed
    2008 Superduty 6.4 Twin Turbo
  2. #22
    Super Member sullysdetailing's Avatar
    Mar 2009
    South Florida
    1,963
    Quote Originally Posted by Superdutytd View Post
    It all refers back to what Mike Phillips say "Find something you like, use it often"
    Some people like the lightweight some like the heavier one it all up to the user
    Shawn
    Sully's Detailling LLC - South Florida
    www.autogeek.net
  3. #23
    Aug 2008
    1,715
    I'd like to chime in with my $0.02. I just got my Flex 3401 DA last week and I don't have much experience with it since I've only been spending the past week polishing my vehicle and that's it, so my 2 cents is probably only worth $0.0002.
    But here goes...the Flex is WAY more powerful than a PC7424. They are not even close in pure cutting power and speed. The Flex DA breaks the polish down faster and has much more cut. I have been comparing the two side-by-side using 106FA and the LC Hydro-Tech Tangerine Pads (6.5" for the Flex and 4" for the PC7424). The PC seems to only be able to refine the surface and make the scratches a bit less visible. The Flex just completely eliminates them.
    Now my beef is that while the Flex is much smoother than the PC7424, it just keeps trying to walk on me...it's okay on horizontal panels; but side panels become very difficult to polish at speeds higher than setting 4 because it's hard to balance and the machine tries to walk no matter what, mainly because of having so much more power than a PC. It doesn't bog down or stop oscillating even under lots of pressure. I think more time will allow me to get the hang of it but overall it seems to take the same amount of effort to polish each 2x2 area, but it does give ridiculously good results.
    Edit: I am definitely not buying any more machines any time soon. But for people considering or wanting the Flex DA, you should also consider what you would do when it comes time for spot-buffing or basically doing small/tight areas. You can purchase a $50 Edge adapter and use the Edge 4" pads but that's even more money to the already-expensive Flex. With the Flex light-weight rotary, you could just buy an additional smaller backing plate (which is cheaper) and use smaller pads with one machine; and you're not limited to a certain type of pad. This gives you a lot more flexibility.
    08 Subaru WRX
  4. #24
    Super Member VISITOR's Avatar
    May 2007
    9,730
    Quote Originally Posted by Emile View Post
    So I think I may purchase the Flex L3403 sooner or later because I really want a smooth and enjoyable polishing experience.
    one can never have enough quality power tools, and that would be a great companion with the Flex 3401...
  5. #25
    Apr 2009
    113
    Emile,
    Do you think the Flex 3403 would also yield the same results as the DA, and easier to control on the vertical panels?
    The flexibility of using different pads sizes + price difference seems to swing in favor of the 3403.
  6. #26
    Super Member Harleyguy's Avatar
    Jan 2009
    Parkland South Florida
    2,349
    Quote Originally Posted by jrt81 View Post
    Emile,
    After the class we had some time so Mike let me use the L3403 on my vette mind you i own a Pc orginal one a Makita rotary and have a Flex Da on loan.Using the L3403 on the sides of the vette was a night and day defference between the Flex and Makita the weight of the machine was the selling point.As far correction between the two they were the same.On the top panels the weight doesn't really become a factor.I know alot of detailers that like the extra weight of a Makita or a DeWalt.If you want to learn using a rotary i would skip the Flex da and spend the money saved on extra backing plates and smaller pads.
    Lamborghini Broward
  7. #27
    Aug 2008
    1,715
    Emile,
    I would definitely hope so but I have never touched a rotary. In his last post, Harleyguy said this is definitely the case...great results and smooth polishing on vertical panels, much better than the Flex DA.
    I personally went with the Flex DA because I wanted a much better machine but with the safety and familiarity of a DA polisher. My next step will be the Flex L3403, no question. I just have no idea when that will be.
    08 Subaru WRX
  8. #28
    Aug 2008
    1,715
    Quote Originally Posted by BigAl3 View Post
    Agreed. I would be an unstoppable week-end warrior.
    08 Subaru WRX
  9. #29
    Sep 2006
    2,397
    I personally like the VVB rotary. It is superbly balanced. Not only that but the weight of the machine just makes it glide over paint while correcting. I also just like the feel of it more than a smaller buffer.
    Autogeek OG. Attended detail fest I/II. Still detailing!
  10. #30
    Apr 2009
    113
    Harleyguy,
    How would you compare the Flex DA against the 3403 in terms of smoothness?
    Do you experience the 'pad skipping' or 'walking away symptom' like Emile posted?
    I'm about to place an order, but still torn between the Flex DA and the 3403.
    Is it to assume that the 3403 would be smoother to use, than say the DA?
  1. New FLEX PE8 Lightweight 3 in rotary polisher
    By RobRabbit2.5 in forum Off-Topic
    Last Post: 11-10-2014, 03:32 PM
  2. FLEX L3403 VRG Lightweight Circular Polisher
    By HateSwirls in forum Flex Polishers
    Last Post: 01-15-2014, 05:31 PM
  3. FLEX XC 3401, FLEX L3403, or FLEX PE14-2-150 for Gel Coat
    By MichaelD in forum Boat & Marine Craft Detailing
    Last Post: 10-16-2012, 01:28 AM
  4. Ordered my first Flex L3403 VRG
    By Desert Detail & More in forum Off-Topic
    Last Post: 02-27-2012, 03:11 AM
  5. Flex 3403 Lightweight
    Last Post: 02-09-2010, 09:10 PM
