Results 1 to 4 of 4
    Super Member imageautodetail's Avatar
    Jan 2008
    Louisville KY
    432
    Anyword on a smaller flex BP
    Has there been any more on a smaller backing plate for the DA or an adaptor, I have about 50 - 5 inch orange pads just itching to go for a ride on the Flex DA, the flex rotary has been to boring for them, By the way I got the flex LW rotary for X mas, and havent used my Makita since... So yes it has tested true for me.
    Super Moderator Meghan's Avatar
    Mar 2006
    Florida
    15,036
    Re: Anyword on a smaller flex BP
    No word yet but Flex will be at Detail Fest so we will check with them.
    Super Member ScottB's Avatar
    Mar 2006
    South Florida
    18,803
    Edge adapter is only thing I have seen to date ... cannot even find out if more will be made.
    Super Member gewb's Avatar
    Oct 2008
    Denver, Colorado
    562
    If you have access to a lathe, purchase a backing plate and have it turned down to 4.5 inch (114 mm) diameter (minimum usable diameter looks to be 112 mm or 4.4 inches). Local shop should be able to do it in 30 minutes or less. Use a 5 inch pad.
    Regards,
    GEWB
    Linux Reg. User #206357 (Feb. '99)
    "Can't get there from here."
  1. How do i use smaller pads on my flex 3401?
    By Rez90 in forum Ask your detailing questions!
    Last Post: 09-01-2011, 01:56 PM
  2. New smaller Flex backing plate pics
    By Bunky in forum Flex Polishers
    Last Post: 03-30-2011, 05:58 PM
  3. Flex DA smaller pad conversion?
    By CEE DOG in forum Auto Detailing 101
    Last Post: 12-03-2009, 03:14 PM
  4. Can you get smaller than 4" pads on Flex 3401
    By unclestu in forum Flex Polishers
    Last Post: 09-29-2009, 09:44 PM
  5. So You Want to Use Smaller Pads with your Flex ???
    By ScottB in forum New Car Care Products
    Last Post: 05-12-2009, 08:33 AM
