Results 11 to 20 of 21
    Feb 2013
    662
    Re: Ordering Flex 3401 - Questions
    Why anti long throw? If you’re doing a 3” it’s the perfect mate. I’d only do a 8mm rotation if I wasn’t getting a mini.
    Also lots of complaints on G8. I would do g13. I’ve tried both and it is a superior machine.
    Idk this is becoming quickly very overwhelming. Everyone has a different opinion of course. That said after many hours of research it seems a lot more people complain about pad stalling and issues with long throw vs those that recommend it. Even Mike Phillips seems to be a much bigger advocate of forced rotation over these long throw polishers
    Feb 2013
    662
    Didn’t recommend cordless…
    FLEX XCE 10-8 125 Corded Polisher
    Ahhh okay my apologies. So that’s the model to get then…
  3. Likes Coatingsarecrack liked this post
  4. #13
    Aug 2010
    New Jersey
    15,168
    Quote Originally Posted by CC268 View Post
    I'm looking at that one, and it doesn't look like you can use the smaller 3401 backing plate that people have mentioned. What I see is it comes with a 6" backing plate, and that you can install the 5" backing plate from the long throw machine, but not the 5.5" one that goes on the 3401, or the ~4.5" one that you can get for the 3401. The Hercules is compatible with the 3401 backing plates. Maybe someone else can confirm/clarify the backing plate sizes/compatibility.
    PS Also, I presume the Hercules backing plate is actually 5.5 like the 3401, even though the documentation implies it's 6"
  5. #14
    Super Member opie's Avatar
    Mar 2021
    Pa
    2,226
    6.5 LC force pads are what i use on my flex supa beast(aka 10-8 125). White and orange.
    I also run the 6 inch backing plate. 9 times outta 10 you can just run the pad up on edge in a small area. And if the are still need something smaller, then i toss on a 3 inch pad on my flex rotary.
    I feel those two machines will take care of damn near anything one might come across.
    Using free spinning da machines, weither 5-6inch or 1-3 inch pads are so time consuming and slow.
    If you are looking to paint correct more than a vehicle or two a year..and can afford it, imho i feel the best decision is to just get a flex supa beast, then if the need arises later down the road...get a rotary.(flex imo)
  6. Likes Coatingsarecrack liked this post
  7. #15
    Super Member VISITOR's Avatar
    May 2007
    9,728
    if you want to stay within the flex family (and don't mind spending more), a great choice would be the 3401/supa beast and the pxe 80 and you will have all your basis covered. there's also a flexible shaft extension for the pxe 80 which will allow you to use little conical/cylindrical pads for the intricate tighter areas...
    i am the jump starter.
  8. Likes Coatingsarecrack liked this post
  9. #16
    Feb 2013
    662
    Quote Originally Posted by opie View Post
    Thanks a lot for the feedback. I think I will go with the 6.5 LC Force Pads. Do you find that the orange pad finishes well or do you have to follow up with something else?
  10. #17
    Feb 2013
    662
    Yea that is exactly what I was thinking. Supa Beast + PXE80 would be an awesome combo.
  11. #18
    Mar 2021
    Pa
    2,226
    The orange has always finished down without needing to go further for me. I do mostly only use orange for one step corrections where a white pad is not agressive enough
  12. #19
    Feb 2013
    662
    Fantastic thanks! I will likely just order the orange pads for now then.
  13. #20
    Dec 2018
    7,173
    No definitely force rotation is better at anti stall and other positives and benefits. I have a g15…. Love it. Going cordless so bought a c beast.
    My comment was vs the G9. Paired with a 3” a g15 will perform better for you. For a novice less chance of burn through with a free spinning DA. You seem to be looking at quality products and I promise you’ll be happy no matter what you order.
    Mike Phillips prefers flex because he does a lot of cars and a flex will definitely polish faster.
  1. Flex 3401 Pad Questions
    By Zubair in forum Flex Polishers
    Last Post: 07-31-2015, 03:14 AM
  2. Flex 3401 questions
    By jafo1219 in forum Ask your detailing questions!
    Last Post: 06-01-2015, 06:10 PM
  3. Questions about pads and the flex 3401
    By touringsedan in forum Auto Detailing Tools and Accessories
    Last Post: 05-06-2012, 10:08 PM
  4. Few Flex 3401 Questions/Comments
    By Wills.WindowsAndWheels in forum Auto Detailing 101
    Last Post: 07-02-2011, 02:26 PM
  5. Ordering 3401, Need Help With Everything Else!
    By SlamMan in forum Flex Polishers
    Last Post: 11-21-2010, 02:38 PM
Members who have read this thread: 34
