09-09-2008, 06:43 PM
#131
Re: FLEX XC3401 problem
I would also suggest limiting the pressure you use when using the Flex, it doesnt need it like the PC and might be some of the problem.
09-10-2008, 08:01 AM
#132
do not over tighten the bolt this causes problems too according to Flex. Put a good amount of oil on the felt it will not hurt anything or "sling" (I have not had any problems) I have laid into mine VERY hard a couple times and had no issues {crosses fingers} I do think it is a great machine
Mike
86 Buick T-Type (turbo terror) White
08 Corvette Coupe Velocity Yellow
10 Lincoln MKS Red Candy
09-10-2008, 08:20 AM
#133
Wow, All I had heard about the Flex was rave reviews, I have a Cyclo built in 1953 that was abused at the Fire Department and was in the trash can because the plug was broken. I dug it out and replaced the plug $4.95 and I use all the time.
I'm not a pro and seem to have read that it won’t do Paint Correction like the rotary BUT the prices are not that far off. I would Go Cyclo if I was a newbie, am I missing something?
09-10-2008, 11:13 AM
#134
we certainly dont want to raise this battle again, as each machine has its faithful. The power, orbits, adjustibility, and speed sensitive trigger are nice reasons to own a Flex.
09-10-2008, 11:55 AM
#135
I wasn't trying to re-open any old wounds; I was genuinely wondering if the Flex was really the machine I had heard it was. I hadn’t heard about any issues until this post and there seemed to be quite a few with the same issue. Maybe a bad batch?
The reason I asked was because I was thinking of adding a Flex to my arsenal and was wondering if I should or not. The question wasn’t meant to criticize, guess I phrased it incorrectly. You guys are touchy when it comes to your tools. LOL
09-10-2008, 01:37 PM
#136
Maybe a bad batch?
hundreds of Flex's have been sold and there have been only a handful of incidents. it's like anything else these days...
09-11-2008, 07:00 AM
#137
Does using a double washer help matters? Also, where and what kind of washer?
09-11-2008, 04:58 PM
#138
I was told the exact same size as the one already used. Plan on taking it to Lowes this weekend the carry draws full of this stuff.
09-14-2008, 07:04 PM
#139
ZoranC
Where do you put the second washer? With the one you tighten the backing plate with? Or is there another spot?
10-08-2008, 09:28 AM
#140
If you do 2 things, lube the felt, more is better, and DO NOT overtighten the bolt the machine is simply the best IMO. More problems have come from overtighting that anything. Lube is as problem that should have been addressed by Flex but was not.
Mike
By jpegs13 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 03-03-2010, 05:14 PM
By gasterus in forum Auto Detailing Tools and Accessories
Last Post: 05-07-2008, 05:13 PM
By k20z3kid in forum Flex Polishers
Last Post: 03-20-2008, 06:57 PM
26 | 27 | 28 | 29 | 30 | 31 |
