Results 1 to 5 of 5
    Super Member sayroger's Avatar
    Nov 2013
    316
    Flex3401 loosing rpm
    When using my 3401 it looses rpm it is hooked up to a heavy duty extension cord. I can move the cord around going into the machine but it doesn't make any difference. If I let off the trigger it will come back up for a little while then drop back off. It is 3 years old. Any clue on how to trouble shoot.
    Super Member VISITOR's Avatar
    May 2007
    9,767
    Re: Flex3401 loosing rpm
    try calling powerhouse distributing in Omaha, NE. they were the first repair facility in the USA for flex polishers...
    Nov 2013
    316
    Thanks I called they could not tell me what it was without looking at it.
    Aug 2013
    Tustin, CA
    4,389
    One thing I like about the Flex 3401 is that it is an easy DA to repair. Since you are no longer under a warranty I would fix it myself. I had a similar issue after beating the snot out of it. I have dropped my Flex on more than one occasion. Everything started to slow down and actually took a while to start going to the proper setting RPM. Then one day it just stopped working. I DO NOT have the extended cord just the stock cord it came with.
    BEFORE YOU DO ANYTHING, check the gauge of the extension cord as that might be the culprit. I have heard if you do not use the proper gauge of extension cord, it will not function properly. I would ask Powerhouse if that is the case.
    If that isn't check your carbon magnets (more than likely fine) and the trigger piece. The Flex 3401 is modular in design and parts can be easily replaced. I replaced my trigger and my Flex works great. I think that part is like $90 but that was almost 2 years ago. I hope I helped a little. THAT WAS MY ISSUE and may not be yours.
    But based on your description if it isn't the gauge on the extension cord then replace the trigger module. If I had to guess....the extension cord is the problem.
    But again a guess....PLEASE let us know the outcome so us Flex guys will have additional ammo for future repairs on the Flex
    CJ
    Save the Manual!
    Aug 2013
    Tustin, CA
    4,389
    Quote Originally Posted by sayroger View Post
    Sorry that they were no help! That sucks! You tube the problem...but again I say extension cord is more than likely the culprit.
    CJ
    Save the Manual!
  1. Back to the Flex3401
    By HateSwirls in forum Flex Polishers
    Last Post: 09-19-2018, 08:54 AM
  2. Flex3401
    By newguy2 in forum Flex Polishers
    Last Post: 02-21-2014, 09:56 PM
  3. Just Tired of loosing stuff in the Shop
    By TCFatboy in forum How to make money detailing cars
    Last Post: 06-05-2013, 02:26 PM
  4. what to use with my new flex3401
    By 05rsx911 in forum Auto Detailing 101
    Last Post: 02-22-2012, 05:46 PM
  5. Either I'm loosing it or....
    By D.Acker in forum Off-Topic
    Last Post: 02-17-2012, 11:04 PM
