Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Jul 2013
    37
    FLEX 3401 not working right, erratic speed... Please diagnose!
    Hi there, I've been searching the forums and Internet looking for someone with the same problem do I know what needs replacing, as in on a limited budget and don't use my flex daily... Here is the issue I've been experiencing:
    The speed seems to vary as I'm using it... Like I can be on speed 5 or 6, but pull the trigger and sometimes the speed acts like 2 or 3. The control wheel seems slow to react to changes, and sometimes you can even hold the trigger in with the machine running and turn the speed adjustment with no actual change to the speed of the machine at all, or a very slow reaction to the speed change on the dial.
    Now my first thought was that it's gotta be the speed controller assembly (over 70.00 plus shipping) but after reading some other posts including one just below this one, I am now thinking it could simply be the brushes... Which quite honestly aren't cheap either at about 40.00 shipped for a pair. Other posts I've seen speak about the trigger switch itself causing similar issues, but I honestly don't think that's my issue. Cord is good for sure. I don't want to buy a half dozen expensive parts trying to fix one issue... But also don't want to buy the wrong part.
    I've even considered just buying another one and selling mine to someone else who knows what it needs... As used ones seem to sell for quite a bit, even with issues... And i don't know what parts to buy to fix this one. That seems like a potentially expensive solution though. I am looking for help!
    It's a few years old, but hasn't been used more than a dozen times I'd guess. Although those were all full details, some being large pickups and SUV's. Any ideas would be appreciated, but hoping to hear from someone who has experienced this exact issue and knows for certain what fixed it.
    Re: FLEX 3401 not working right, erratic speed... Please diagnose!
    Hi Joey,
    I'll send the link to our thread to Chris Metcalf. He should be able to diagnose this issue.
    Hang tight, we talked yesterday so I know he's around.
    Jul 2013
    37
    Thanks Mike... That would be great.
    FLEX is fast!
    I called Chris Metcalf and also sent him an e-mail with the link to your thread, he sent it to Davey Snyder at PowerhouseToolParts.com the official repair facility for FLEX tools and here's what Dave had to say,
    Date: April 7, 2017 at 7:00:39 AM MST
    To: 'Chris Metcalf' <cmetcalf@flexnorthamerica.com>
    Subject: RE: FLEX 3401 not working right, erratic speed... Please diagnose
    Of the more common possibilities that could cause problems like that described, the first being cord problems at the end of the strain relief where all the flexing occurs.
    Many times this is mis-diagnosed by those attempting their own repairs. The way to properly diagnose it in this particular situation is to lay the tool down on it's back on a work bench and not move it as the switch is triggered to the [ON] position and locked into place.
    If it operates, then bend and twist the cord at that point to prove that it is definitely not the cord.
    If bad, the unit will stop and not restart till the switch is released and then restarted.
    This is THE most common problem. That doesn’t mean to say that there are other things that could occur, such as loose connections elsewhere, sticking brushes, loose brush springs, faulty switch or speed control, or other possible scenarios.
    I wouldn’t recommend attempting repairs unless you have a basic knowledge of electricity, and understanding of volt/amp/ohmmeters, otherwise send it in or entrust it to those that do understand.
    Otherwise it is a guessing game and everyone’s time just gets wasted.
    Dave Snyder
    dsnyder@pwr-house.com
    Power Tool Service and Parts Supply - Omaha, NE | Powerhouse Distributing
    11011 i ST
    Omaha, NE. 68137
    PH: 888-809-4749
    FX: 888-809-4748
    Quote Originally Posted by joeybsyc View Post
    Hi Joey,
    I just posted what Dave at PowerHouseTools recommends.
    Give his suggestions a try and if that doesn't isolate the problem to the cord and were it enters the body of the tool then give me a call.
    1-800-869-3011 x206
    For everyone reading this into the future, two comments... (not directed at you Joey, I just practice typing for the future)
    First - If and when a FLEX tool breaks it's the exception not the rule. These are the Mercedes-Benz of polishers. The if and when a tool breaks it can often be traced back to a non-tool reason. See my next comment.
    Second - Talking to Chris Metcalf, he said the MOST common cause for failure of any of the electronic parts inside ANY tool, be it a FLEX, DeWALT, Porter Cable, fill-in-the blank, it's due to using too wimpy of an extension cord. And Chris says from his experience in this industry he sees guys using cheap extension cords with to small of gauge wire all the time.
    In fact it is such a problem that FLEX took the proactive step to introduce their own heavy gauge extension cord to,
    A: Solve the problem.
    B: Educate the public
    In fact, I have an article on this... (yeah I know, sometimes even I can't believe I have an article on extension cords)
    Sneak Peak! FLEX 50 Foot Heavy Duty Extension Cord - Tool Insurance and Power Efficiency
    The problem
    If you use to light of gauge wiring in and extension cord the wire itself hinders the flow of electricity to the tool. This can harm the electrical components inside the tool and cause these components to burn out. The cord itself will get hot due to the impedance of electricity flow. In fact, you should NEVER feel heat or warmth coming from your extension cords when using FLEX tools. If you do this is sign that the cord is too light duty for the tool.
    The solution
    A heavy duty extension cord that uses a minimum of 12 AGW wire. The longer the cord the more important it is for the cord to use 12 AGW wire. The FLEX 50' Heavy Duty 12 AGW Extension Cord is the solution FLEX offers all their tool customers to protect their tool investment while providing the correct flow of electricity to the tool.
    So when you invest in high quality, high dollar tools, include in your budget some funds for the appropriate heavy gauge extension cord. It will protect your tool investment.
    On Autogeek.com
    FLEX 50 ft. 12/3 SJTW HD Extension Cord
    Jul 2013
    37
    Thanks Mike... I will look into that when I get home from work, but I honestly do not think the problem is with the cord. I also will admit I'm no electrician! What kind of a deal could you give me on a brand new one? Any specials or sales coming up on Flex 3401's? Joeybsyc@aol.com
    Aug 2010
    New Jersey
    15,173
    . If you use to light of gauge wiring in and extension cord the wire itself hinders the flow of electricity to the tool. This can harm the electrical components inside the tool and cause these components to burn out. The cord itself will get hot due to the impedance of electricity flow.
    I have heard this many times but I have never heard a good explanation of what happens. The cord getting hot means the heat (due to voltage drop) is being dissipated in the cord, not the tool. Can Chris explain how excessive voltage drop in the extension cord causes components inside the tool to burn out?
    If you have voltage drop in the cord, that means the tool isn't getting 120 volts, but some lesser voltage. Since the winding resistance of the motor is a constant (notwithstanding how the speed control works), then using Ohm's Law, the tool would be drawing less current than normal, less current should mean less heat, less heat does not equal burning out, at least in my mind.
    So to me, the end result would be the tool running slower or not having as much power as normal, not burning out. Unless of course you are more likely to stall the motor since the tool isn't at it's full power output, and stalling would certainly create a lot of heat as the cooling fan wouldn't be turning. Of course this could be some motor thing that I don't understand, which is why I'm asking.
    Yes I can get Chris to explain it all, he's very good at this.
    Once you read what he share's you'll be a believer.
  10. #10
    Sorry to say... I'm not the wheeler-dealer here at Autogeek. I'm more of the how-to guy.
    I can check with Andre as he IS the wheeler-dealer guy here at Autogeek about any sales or good deals.
  1. Flex 3401 stopped working
    By david b in forum Flex Polishers
    Last Post: 09-01-2019, 12:43 PM
  2. Flex 3401 intermittently working
    By Ted Y in forum Flex Polishers
    Last Post: 07-12-2015, 08:04 PM
  3. Flex 3401 Stopped Working - Brushes?
    By grambow in forum Flex Polishers
    Last Post: 03-06-2015, 11:38 PM
  4. Test Spot vs Working Area - Using a Flex 3401
    By bwatereagleman in forum Ask your detailing questions!
    Last Post: 06-09-2014, 03:49 PM
  5. HELP urgent! Flex 3401 stop working
    By fabz in forum Flex Polishers
    Last Post: 12-21-2011, 12:42 AM
