Re: Important* new flex polisher question
Originally Posted by nothingface5384
i
ill check to see if my backingplate has sidewobble...but as for the walking issue..
if you keep the polisher level/pad flat the issues will be virtually eliminated...as I still have minor walk/push on the lower panels like the bottom door or rockers.
you also need to hold the polisher differently then if you would with a GG6 or Boss/rupes longthrow
instead of vertical..hold it almost horizontal sasy like 2 oclock or 10 oclock depending on if youre lefty or righty
and NO it doesnt have wobble..you can attempt to rotate it and hear a sound before it locks but that about it
no i know it took me a while to figure out its broken. that little wobble throws everything off. looking back now you can tell by the polishing trails its bouncing all over the place. its just a defective tool
also to add i have my new g15 to compare it to and the g15 is solid.
Originally Posted by DaveT435
Sounds like maybe the screw is cross threaded, if the screw feels tight but the p,ate is loose. If you haven't taken off or put on the backing plate I wouldn't. Make sure the washer is there. I would contact Flex USA before you do much if anything. If it's a cross threaded screw and you've taken it off it would be normal for them to think you cross threaded it...
its not cross threaded bro, i know what you mean though, everything is in right the backing plate is just not secure to the machine. i just want a new one because its such an expensive tool. they can figure it out and sell it refurbished or whatever.
i think the fact that the backing plate is hard plastic instead of metal may have something to do with it.
edit.. i emailed customer service, gave them the order number and told them the problem hopefully they will get back to me soon. i told them i dont want it fixed i just want a new one thats not broken. i bought it like two weeks ago but last night and today was my first time using it. im not blaming autogeek i know they dont manufacture the thing
thanks for all the help guys
Looky here I can make it move.
maybe you can but its not supposed to. mines broken its just about unusable with a 6.5 inch pad. i know its not right its not a little movement its a lot. is that even the factory backing plate you have on there?
can you shake the plate back and forth easy and make noise? thats what mines doing
It is the factory backing plate I shaved down to 5 inches. It clicks back and forth when I tug on it, always has.
It has worked great for 3 years.
That's really strange, the way the parts are manufactured I don't really see what would cause that except a cross threaded screw or the backing plate itself broken. So obviously you've removed the backing plate and put it back on? Can you actually see what's broken? I want you to understand I'm not doubting you in any way, just curious because in the years I've been on here I've never heard of anything like this on here. With any manufactured product there is going to be a percentage of defects. Flex percentage seems to be very low. Can you actually see what's broken, have you turned the machine on a low speed with the backing plate off to try to see where the problem is?
2015 F-150 Crew Cab Lariat
2016 Chevrolet Camaro 2SS
Post pictures or better yet a video
It sounds like the bp is not sitting flush to the spindle. I had a customer that for whatever reason had the wrong size (length) screw and it would not lighten down, thus the wobble.
I would still make sure you call them tomorrow morning. I haven't had much success getting a response from them when I email.
When I had my 3401, I could definitely rotate the plate side to side a fraction of a millimeter, but not to or from the tool.
Last Post: 12-04-2019, 07:35 PM
By awancorp in forum Ask your detailing questions!
Last Post: 09-24-2019, 03:12 AM
By SON1C in forum How to make money detailing cars
Last Post: 06-04-2012, 12:45 AM
By Kris R in forum DetailFest Archive 2006 - 2017
Last Post: 02-24-2012, 08:53 PM
By Kris R in forum Autogeek's DetailFest Info
