Re: What (mini + carpet brush)machine to buy next to flex!
Back again
Now I'm a little confused
Which one is more reliable griots 6 or pc xp
I will buy it online
So I will not have warranty in my country
What I read pc is very reliable
What about griots?
Thank you
Sent from my EDI-AL10 using Tapatalk
The Griot's Garage polisher comes with a lifetime warranty, which won't help you. It does, however, indicate that Griot's Garage has a lot of confidence in the unit. Gary Dean has had one failure with a GG6, but it was replaced under warranty, and it was the only failure that I have heard of.
The Porter Cable 7242XP comes with a shorter warranty (1 year, I think?). However, the unit is considered to be extremely durable, and there are many of the older 7424 that have been in use for over 10 years. They literally don't break. I would suppose that they would if somebody dropped them onto concrete from 25 feet up, or if you overheated them by running a long extension cord that was too small a gauge, but in normal use, they don't really break very often.
Have you verified that they are available in your location's voltage?
Thank you for your reply
Actually I found old post about gg6 broken
http://www.autogeekonline.net/forum/...ad.php?t=71345
And there's another one I couldn't find it now
And what amazing about pc
I found someone his machine broke
Nearly after 9 years wow (old version not the xp)
That's really amazing because of that I believe it's the device for me
But you know gg6 has more power
Because of that I get confused I want someone confirm if the gg6 has also good reliablety
I contacted griots they said I it's not available in my country so I have to buy it online
I contacted PC
They didn't say anything yet I'm waiting for there replay
They keep saying someone will contact you after 10 days and 5 emails
No one till me if it's avaliable here or not
So I'm waiting again and again for simple question!
Because if it's avaliable for sure I will buy it locally
Otherwise I need to decide which one Is more reliable
And I contacted both pc and griots agien about the devices if they have 220V
I'm waiting there replay
Thank you again
Waiting more reply from old user for griots about reliablety of there devices
Griots replay now they only have 110v
I will search for griots in Europe I think they have 220v
Sent from my SM-G935F using Tapatalk
Sorry can't update last post
Anyway pc now they reply
They said pc only avaliable on North America
So it's mean now I should check if I can find griots in UK it will be 220v
Otherwise I should do search again for another device
I found cyclo but the price 600 usd it's expensive because in anyway I'm going to buy flex
And cyclo not in my country so there's no warranty also! But it's 220v
I need cheap polisher now that I can use it for carpet also
From what I heard here there's rupes I can buy it locally
And bosch
And meguiar's
And off course flex
I don't know if there's other companies here
Thank you everyone
Hi,
You could always check to see if the Bosch 1250 DEVS is available in your country. It is a dual mode device that can be a forced rotation (like a Flex 3401) and a free rotation (like a PC or a GG6, or pretty much the same as any other random orbital polisher) with a flip of the mode switch. Only thing is, it is only a 6" backing plate, so no change of plate sizes. Might be the best all around solution if it is available in 220V. I suppose you can also look at an XC3401 and a Flex XFE7-15 as well, but that is two very expensive machines. There are some DAS 6 machines that that are 220/240 V, ans seem to get a good review on the Forensic Detailing youtube channel (I think he favours the DAS6 Pro Plus). They don't seem to be too expenisve. He doesn't go into backing plates much, so I don't know if they would have different sizes available.
Junkman2000 did a review of it on youtube.
And bosch
And meguiar's
And off course flex
Thank you everyone
600 for. Cyclo is way too much . Should be 350 usd 399 tops
Actually it's 650 usd with shipping to my country! And no warranty!
model number :
5C - Pro mark II 230V
Hi,
Thank you
You made my day!
I was thinking to buy pc and change the output in my wall to 110v
Just to use pc
Or I have to forget about machine carpet brush buffer
When I search for das 6 pro
I found interesting information
(same as Porter Cable) I hope what in my mind is right the brush for pc will work with das 6 if I understand correctly!
Specifications:
Orbit Size: 8mm
-Backing Plate Thread Size: 5/16" (same as Porter Cable, G220 and UDM's)
-Variable 6 Speed Dial: 2,500 to 6,500rpm
-Weight - 2.3kg (approx)
-Supplied with#two Velcro Backing Plates Size: 125mm ( 5” )# and 150mm (6")
-Fits 5", 6" and 6.5" polsihing pads
The brush carpet here on autogeek store
Is for pc and griots
http://www.autogeek.net/porter-cable-brushes.html
If the same brush will work on das 6 pro
Will be perfect machine for me
I need to contact autogeek and das 6 manufacturer to confirm this!
Forget to mention bosch not perfect for me I'm sure it's great machine
And I want now cheap and good Polisher
For me it will be first machine to start and learn with
And in the same time I can use it for carpet and cleaning leather
I'm waiting until Flex XFE7-15 arrives to my dealer after 2 month
So flex will be for Polish and the older for leather and carpet only!
If flex has good carpet brush i will not think about another machine
But they don't have
Thanks again everyone
Here's another catch
On Forensic Detailing Channel on das 6 pro review
The das 6 pro same design as griots 6
Actually its made by griots manufacturer
Up to reviewer
Here's image for das 6 pro
So is that make sense!
The carpet brush for griots will work with das 6 pro?
I think the same teviewer did another video that went over all of the DAS 6 polishers in great detail; the original DAS 6, the DAS6 Pro, and the DAS6 Pro Plus (all 4 models/versions). Before making a final choice, you should look at that, just to be sure.
The spindle on the Porter Cable is a 5/16 x 24 thread. While it is originally PC, most polishers use it (not Flex or Rupes).
Last Post: 04-30-2020, 11:08 AM
Last Post: 07-30-2018, 01:38 PM
By bym007 in forum Auto Detailing 101
Last Post: 03-18-2016, 05:42 PM
By Matt@Revive in forum Auto Detailing Tools and Accessories
Last Post: 04-29-2015, 09:27 AM
By RobertJ34 in forum Product Reviews
Last Post: 04-21-2014, 11:11 AM
26 | 27 | 28 | 29 | 30 | 31 |
