Results 1 to 2 of 2
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    DP Tire Dressing
    This was included when I was picked for the Project 98 give away package.
    So many tire dressings on the market........
    This provides a satin to semi gloss depending on tires. Gloss can be amped up with a second coat.
    Really darkens the tires to get the midnight black look.
    Zero sling
    Dries to the touch.
    Bubble gum scented.
    Water based and rather durable. It actually will bead water up. I can go quite a few washes without reapplication.
    Spray form. I prefer to spray on the speed master applicator then apply. Speed Master Tire Dressing Applicator
    Little goes a longggggg way.
    Summary: In a world full or tire dressings, this stands out. It’s not ghetto glossy, looks sophisticated, last and doesn’t make a mess on the side of your vehicle. I like water based dressings as solvent based can be an icky mess. If you are looking for a water based sprayable dressing, I would suggest this.
    After my current water based tire dressing is used up, this will be my new go to.
    Jim
  2. Likes Pats300zx liked this post
  3. #2
    Mar 2011
    PA
    5,794
    Re: DP Tire Dressing
    Sounds like a winner. I also have a bottle to try after my Duragloss #253 stock is gone. Almost sounds like DG #253.
    2018 Colorado ZR2
  1. Replies: 16
    Last Post: 04-09-2019, 12:43 PM
  2. Replies: 31
    Last Post: 05-27-2018, 12:06 AM
  3. Replies: 29
    Last Post: 05-26-2018, 09:13 PM
  4. Meg's D160 All Season Dressing as tire dressing?
    By 7.3powerstroke in forum Products Guides
    Last Post: 03-24-2016, 08:48 PM
  5. Replies: 12
    Last Post: 11-27-2013, 09:20 AM
