Results 1 to 5 of 5
    Dec 2009
    Cyclo Pads rubbing against each other.
    Hi, I'm a new Cyclo user. I'm currently using the orange foam pads and the hook & loop pad holders that came with the package. My question is if it is normal that the foam pads rub against each other leaving a trail of shredded foam on my paintwork? I've done all I can to center both adapter and foam pads and they still rub. Thank you in advance for any advice.
    Nov 2010
    Northern CT
    208
    Re: Cyclo Pads rubbing against each other.
    Are the pads centered exactly? What pads are you using?
    Super Member RTexasF's Avatar
    Jun 2006
    North TX
    2,582
    Your pads or the holders (or both) are not centered.
    Rick....now in North Texas
    Dec 2009
    Goathead & RTexasF, I'm using the hook&loop orange foam pads and the slip on velcro pad adapters that came with the Cyclo. Did my best to center them already. Anyway, I'll go back and check again. I was thinking maybe safer to go with the oem Cyclo pads and the quick attach adapter?
    Dec 2009
    Ok, I tried running my Cyclo without the foam pads. After removing and reinstalling the rubber velcro adapters, they still eventually rubbed against each other. Could my machine be defective?
  1. best pads for cyclo
    By BrandonS in forum Cyclo Polishers
    Last Post: 05-31-2021, 09:40 AM
  2. Cyclo pads on GG6 or 7424xp
    By HardLineDetail in forum Auto Detailing 101
    Last Post: 05-11-2013, 07:06 AM
  3. cyclo pads
    By SPIROS ANTONIOU in forum Cyclo Polishers
    Last Post: 01-27-2011, 10:36 AM
  4. Cyclo and EDGE Pads......
    By justin_murphy in forum Cyclo Polishers
    Last Post: 12-17-2007, 08:22 AM
  5. cyclo pads
    By jim/larry in forum Auto Detailing Tools and Accessories
    Last Post: 09-03-2006, 05:32 AM
