Re: Please help! Meguiar's Gold Class Rich Leather cleaner-conditioner ruined brand new seats !
Originally Posted by carenthusiast
2013 Acura TSX. Will take pictures and post tomorrow, under the normal daylight conditions.
It shines like a plastic .Neither the cheap-shiny Armorall look nor grease comes off after rubbing it with Lyxol. What can I do to get it off?
Where do you live? Maybe we can help you find a professional that owns a steamer. Steam is good at breaking that stuff up. You should also write to Meguiars about your experience. There might have been a problem with the batch.
Brian Dubinsky
ELITE: Luxury Detailing + Paint Protection
Maryland - Northern VA - DC
Thank you for the advise. I would really prefer not to steam it. I have a steamer of my own but didn't use it because steam does damage the leather (it's like a strong medicine, you don't want to take it unless the benefit of it is greater than the harm). My seats don't have a dirt on them (steam is really good in softening and getting rid of glued over years to the surface dirt/dust/sweat ). All I need is safely remove this Meg stuff off without doing any further damage to the seats.
Just a question. How does a conditionner damage a seat? Can you post pictures? From what I understand of conditionners, they contain natural oils to replace the ones that evaporates from the leather with time.
Now, if your seats are not porous, the oils should be sitting on top of the seat finish.
Please explain in more détails what damage was done.
Originally Posted by swanicyouth
I would stop with the OTC stuff. I wouldn't use APC, Woolite, or anything not designed specifically for leather. I would use Strong Cleaner by LeatherMasters. If you don't have it, order it. It works well. Use it with a foam applicator. The blue one from Griots work well, but you can even use a grout sponge halved.
That is what I use, and it doesn't damage coated leather.
I will order and try this stuff.
If anyone had similar experience using megs wipes and then successfully removing them PLEASE share here how you did it.
I am hoping that some of the experts here have dealt with this issue at some point in past and either were able to remedy it or can tell me not to waste any more time on it, if it's now permanently ruined.
P.S. I browsed the net: just on Amazon ,where they also sell it ,there are 10 out of 23 buyer reviews which give this product 1 Star, complaining of the same issue I have experienced.
Calendyr,
The damage is exactly as described in my earlier posts:
1. A brand new, out of factory leather looks like 20 years old used car leather surface with Armorall wiped all over it.
2. The brand new leather looks horrible: TOO SHINY and greasy and I can't get it off now!
3. It shines like a plastic. Neither the cheap-shiny Armorall look nor grease comes off after rubbing it with Lyxol. What can I do to get it off?
You know, Lexol Leather Cleaner has greasy stuff in it. I believe it's glycerin IIR. That's not likely going to help your issue much. Just an FYI anything that is a "wipe" is usually terrible.
Yes, Lexol does have glycerin. I used it in past on my other car with leather seats and never had this Armorall looking shine after the application.
But I realize that with the problem I currently have it's not the best product to counter it.
Thanks for your advises. Unless someone can share of specific experience (having the same problem using Megs wipes and then successfully removing it), I think I will go with the route you recommended.
How about steaming them to open the pores then wipe. maybe some apc diluted and work up the strength if its not up to par. A spinning nylon scrub brush on ur drill bit for added revolution on the apc application.
Someone suggested earlier to take it to professional detailer to steam the seats. I am not sure if I really want to steam them: it does damage the leather and unless benefits outweigh the harm I wouldn't do it. With my seats being brand new I do not think it is the best thing I could do.I have a steamer and I could try it, but only as a last resort.
By blac2k8cs in forum Product Reviews
Last Post: 07-18-2016, 01:43 AM
Last Post: 07-27-2015, 12:50 AM
By otruba_843 in forum Product Reviews
Last Post: 03-05-2013, 10:25 PM
By muscle in forum Auto Detailing 101
Last Post: 09-27-2011, 12:19 PM
