Re: Introducing McKee's RV Product Line!
McKee’s RV Wash & Wax RV Shampoo
Removes dirt and grime while adding real wax protection!
McKee’s RV Wash & Wax RV Shampoo is a thick, high-sudsing wash that removes dirt, grime, bugs, oil, black streaks, and other common contaminants that plague your RV from life out on the open road. Unlike harsh, alkaline-based detergents (they’re everywhere!), Wash & Wax RV Shampoo is a pH-balanced, environmentally-friendly formula that relies on smart chemistry rather than inexpensive butyl ethers and high octane cleaners. McKee’s RV Wash & Wax RV Shampoo cleans and shines your RV without spotting or streaking.
Not all RV soaps are created equal – McKee’s RV Wash & Wax RV Shampoo is proof. There are dozens upon dozens of RV soaps available, but the common trait they all share is harsh, alkaline-based cleaners that strip your wax coating, leaving your RV bare and unprotected. That’s not the case with Wash & Wax RV Shampoo. Our unique, high-foaming formula is pH-balanced and 100% biodegradable. Not only does it preserve your existing wax coating, it reinforces it with real carnauba wax protection!
McKee’s RV Wash & Wax RV Shampoo is the most concentrated RV wash on the market – period! Instead of diluting 1 ounce of concentrate per gallon of water (the industry standard), 1 ounce of our hyper-concentrated formula creates 3-4 gallons of thick, luxurious shampoo. This helps make Wash & Wax RV Shampoo the best value available.
RVs have a much larger footprint than a car or truck, making it nearly impossible to wash them in a shaded area. That’s not an issue for McKee’s RV Wash & Wax RV Shampoo, because it was formulated from the start to be 100% sunlight friendly. Streaks, cloudiness, and water spots are not a concern with McKee’s RV Wash & Wax RV Shampoo. Go ahead and use it to wash your RV in the sun – we dare you!
McKee’s RV Wash & Wax RV Shampoo rinses clean without leaving a film on glass, paint, chrome, or plastic surfaces. Regularly washing your RV with Wash & Wax RV Shampoo will ensure it remains shiny and protected. Our wash formula contains real carnauba wax and UV inhibitors, blocking destructive environmental contaminants from wreaking havoc on your RV’s exterior surfaces.
32 oz.
Made in USA
At McKeesRV.com
McKee’s RV Wash & Wax RV Shampoo - 32 ounce
McKee’s RV Wash & Wax RV Shampoo sounds like it would also be a great product for washing cars on a Car Dealer's lot in the hot sun. You could wash all the cars on the lot and since there is no worry of water spotting, there would be no reason to dry the cars so it would be a huge time saver
McKee’s RV Black Streak Remover
Voted the best RV black streak remover!
McKee’s RV Black Streak Remover is a non-abrasive chemical cleaner that is formulated to quickly and effortlessly remove black streaks from fiberglass, gel coat, painted and metal surfaces. This powerful cleaner begins dissolving black streaks on contact, removing the unsightly stains they leave on your RV’s exterior surfaces. McKee’s RV Black Streak Remover requires very little, if any, rubbing. Simply spray on and rinse off – it’s that easy!
Black streaks plague all RVs!
McKee's RV Black Streak Remover works in seconds and requires minimal effort!
Black streaks are an issue that plagues all RV owners, and they’re something you cannot avoid. Fortunately black streaks are easy to remove with the right product – McKee’s RV Black Streak Remover. The chemists at McKee’s RV managed to formulate a powerful cleaner that requires very little, if any, rubbing. Thanks to a formula that doesn’t rely on harsh acids and high-octane cleaners, McKee’s RV Black Streak Remover will leave your existing wax coating intact.
Black streaks are the result of staining from the runoff of dirt, grime, mildew, and other environmental contaminants from the roof of your RV. These contaminants collect on the roof, decay over time, and rip own the sides of your RV with each rain shower. Unless you clean your RV’s roof on a weekly basis (who has time to do that?) black streaks are something you have to learn to deal with. McKee’s RV Black Streak Remover provides an easy solution for removing these unsightly streaks.
McKee’s RV Black Streak Remover is easy to use! To avoid streaks, spray from the BOTTOM to the top. Allow the cleaner to dwell for 30 seconds and then rinse off. Stubborn black streaks will require a second application along with light agitation with a brush.
Now that you’ve accepted the fact that black streaks are part of owning an RV, here are a couple tips to make them even easier to remove:
1.Regularly clean your rubber roof with McKee’s RV MPC – Multi-Purpose Cleaner.
2.Keep your RV polished and waxed. Black streaks will not penetrate the wax coating, and can easily be removed using McKee’s RV Final Step Detail Wax. Only the most stubborn black streaks will require McKee’s RV Black Streak Remover.
32 oz.
Made in USA
At McKeesRV.com
McKee’s RV Black Streak Remover - 32 ounce
McKee’s RV Heavy-Cut Oxidation Remover
Reverse the effects of the sun and restore the gloss and color of your RV!
McKee’s RV Heavy-Cut Oxidation Remover is like anti-aging cream for your RV! Your RV’s gel coat and fiberglass surfaces are constantly being bombarded by environmental contaminants, the most destructive being the sun. UV rays cause your RV to become chalky and faded, taking away from the appearance of what is arguably one of the biggest investments you’ll ever make. Remove the oxidation with ease by using McKee’s RV Heavy-Cut Oxidation Remover.
Ultra violet (UV) rays wreak havoc on your RV’s gel coat and fiberglass exterior surfaces. The easiest way to maintain the good looks of your RV is to use the complete line of McKee’s RV products from the day you take ownership of your rig. If you haven’t done that, or you’ve purchased a used RV from a less-enthusiastic detailer, than the finish of your RV could probably use a little TLC. If your RV is dull, faded, and chalky, then you need McKee’s RV Heavy-Cut Oxidation Remover to restore the gloss and color.
Compounding and polishing an RV to remove oxidation is known for being a laborious task that requires a lot of time and effort. That’s not the case with McKee’s RV Heavy-Cut Oxidation Remover. This heavy-cut RV compound removes the type of oxidation and staining that other so-called RV oxidation removers struggle with.
Heavy-Cut Oxidation Remover is the only compound you’ll ever need for your RV! Use it to remove oxidation, scratches, scuffs, stubborn black streaks, etchings caused by bug splatter and bird droppings, and spider web scratches. For best results apply McKee’s RV Heavy-Cut Oxidation Remover with a foam or wool pad on a dual action or rotary polisher.
McKee’s RV Heavy-Cut Oxidation Remover is designed for gel coat and fiberglass surfaces. If your RV has a base coat/clear coat finish, a better choice would be McKee’s RV One-Step Compound, Polish & Wax. After using McKee’s RV Heavy-Cut Oxidation Remover, follow up with McKee’s RV All-In-One Cleaner Wax & Sealant to refine and protect the surface.
32 oz.
Made in USA
At McKeesRV.com
McKee’s RV Heavy-Cut Oxidation Remover - 32 ounce
__________________
Cleans, polishes and seals your RV in ONE step!
McKee’s RV All-In-One Cleaner Wax & Sealant is the perfect one-step solution to clean, polish and seal your RV in ONE Step! Use on new and weathered RVs – the outcome will always be the same! McKee’s RV All-In-One Cleaner Wax & Sealant removes oxidation, road film, stubborn bug splatter, black streaks, and other common contaminants that stain and discolor your RV over time. Durable UV inhibitors help prevent UV-induced cracking and fading.
Apply with a FLEX XC3401 equipped with a WHITE Polishing Pad
Your RV’s gel coat, fiberglass, or painted exterior is constantly being bombarded with environmental contaminants such as road film, acid rain, bug splatter, black streaks and accidental gas spills to name a few. McKee’s RV All-In-One Cleaner Wax & Sealant brings new life to your RV’s exterior while sealing it for long lasting protection. The aforementioned contaminants that plague your RV from life on the open road won’t stand a chance against the durable shell of protection provided by McKee’s RV All-In-One Cleaner Wax & Sealant.
McKee’s RV All-In-One Cleaner Wax & Sealant formula was created without compromises. Cleaner waxes are designed to clean, polish, and protect the surface that they are applied to. While they all strive to achieve these goals, many formulas lack in one (or more!) of these areas. That’s not the case with McKee’s RV All-In-One Cleaner Wax & Sealant. This unique formula cleans to remove embedded dirt, polishes to remove swirl marks and oxidation, and seals for long lasting protection.
RVs are BIG, and performing multiple steps can take days or even weeks! Whether your RV is brand new or showing signs of oxidation and fading, save time and money by detailing it in one step with McKee’s RV All-In-One Cleaner Wax & Sealant. Apply by hand or machine – you’ll never find a RV cleaner wax or all-in-one polish that is easier to apply and remove. We guarantee it!
McKee’s RV All-In-One Cleaner Wax & Sealant is formulated for gel coat, fiberglass, clear coat, chrome, aluminum, and stainless steel finishes. Regardless of the surface, All-In-One Cleaner Wax & Sealant will polish and seal it with protection and shine that lasts for the long haul.
32 oz.
Made in USA
On McKeesRV.com
McKee’s RV All-In-One Cleaner Wax & Sealant - 32 ounce
Also available in 16 ounce bottle
McKee’s RV All-In-One Cleaner Wax & Sealant - 16 ounce
Save time - Less steps - Great results!
For large RV's that need a little polishing to return them to their former glory a quality one-step cleaner/wax is the way to go.
The key is using a high quality one-step cleaner/wax. If you use an inferior product the abrasives will remove one set of scratches but leave their own scratches behind.
I teach classes on doing high quality production detailing with one-step cleaner/waxes and trust me... the product is THE most important part of the equation.
Besides the product the next two most important factors are
A: Using soft foam buffing pads.
B: Using a dual action polisher NOT a rotary buffer.
Before
This RV's finish is filled with swirl marks. Finishes like this are all too common, even on brand new RVs.
After
In ONE STEP McKee's RV removed the swirl marks, polished to a high gloss finish, and sealed for long lasting protection
McKee’s RV Water Spot Remover Gel
Remove water spots before they become an issue!
McKee’s RV Water Spot Remover Gel is a thick cleaner that breaks up and dissolves stubborn water spots and mineral deposits on contact. This non-abrasive gel will not scour or haze delicate surfaces and is safe for use on paint, gel coat, fiberglass, chrome, glass, and any other hard non-porous surface on or in your RV. Using a non-abrasive approach helps preserve the affected surface.
If you had to choose only one product to take with you everywhere you go, McKee’s RV Water Spot Remover Gel would be the obvious choice. Water spots plague all RV owners, especially those at RV parks where the water is often sourced from a well. McKee’s RV Water Spot Remover Gel is the best RV water spot remover – we guarantee it!
Thick gel formula dissolves stubborn water spots
Water spots occur because calcium and magnesium stay on the surface after the water evaporates. If left on the surface too long, water spots will etch unsightly rings into the surface that are nearly impossible to remove short of using a heavy cut compound. McKee’s RV Water Spot Remover Gel provides a quick and easy solution so easy to use that water spots can be safely wiped away in a matter of seconds, eliminating the chance of long term damage.
We offer two types of water spot removers – a spray and a gel. The gel is for stubborn water spots, and the advantage lies in its thick formula. Instead of spraying on and wiping off like our other water spot remover, the gel should be rubbed into the surface for 30 seconds and then wiped off with a dampened microfiber towel. Treated surfaces will be clean, shiny, and water spot free!
To make water spots even easier to remove, polish and wax your RV at least twice a year using McKee’s RV All-In-One Cleaner Wax & Sealant. To reinforce the wax coating after using Water Spot Remover Gel, apply a quick coat of Final Step Detail Wax. This will ensure the surface remains glossy and slick, making any type of contamination easy to remove.
8 oz.
Made in USA
At McKeesRV.com
McKee’s RV Water Spot Remover Gel - 8 ounce
McKee’s RV Waterless Wheel Wash & Polish
The no-mess way of cleaning and polishing your wheels
McKee’s RV Waterless Wheel Wash & Polish is preventative maintenance for keeping your RV’s expensive aluminum wheels clean, shiny, and free of oxidation. Use it to clean and polish all types of RV wheels including aluminum, painted, clear coated, and polished. Micro polishing agents gently remove stubborn surface oxidation, road grime, and brake dust while encapsulating polymers provide ample lubrication to ensure the wheel surface is not scratched as you clean.
Spray on and buff to a brilliant shine. Safe on all wheel finishes!
Make the wheels on your RV stand out
Wheels are usually the first part of your RV to feel the affects of environmental pollutants. They’re close to the ground, and the rotating action causes oily road film, dirt and grime to land inside the barrel, wreaking havoc on the beautiful polished finish that you admired so much when you purchased your RV. McKee’s RV Waterless Wheel Wash & Polish is the solution.
Why wash your entire RV when only the wheels are covered in a thick layer of brake dust and road grime? That’s what Bob McKee, the owner of McKee’s RV, was thinking when he presented the idea of a waterless wheel wash to his team of chemists. After a session of brainstorming, the proposition of including micro-polishing agents elevated the project from a good idea to a great new product!
With a spray and wipe McKee’s RV Waterless Wheel Wash & Polish will clean and polish your wheels, leaving them looking as good - if not better - than the day your RV was new. Rest assured this innovative formula doesn’t rely on acids or other high-octane cleaners. As a matter of fact, McKee’s RV Waterless Wheel Wash & Polish is water-based and 100% biodegradable.
Directions:
1. Ensure wheels are cool to the touch before cleaning.
2. Spray a liberal amount of product directly onto wheel.
3. Wipe clean using a soft microfiber towel.
4. Flip towel to a dry side and buff to a mirror finish.
32 oz.
Made in USA
At McKeesRV.com
McKee’s RV Waterless Wheel Wash & Polish - 32 ounce
McKee's RV Safe Scrub Bug Sponge
Bug and tar removal made easy!
The McKee's RV Safe Scrub Bug Sponge is one of the best investments you can make in RV care. You can safely remove stubborn bug guts, road grime, and tar without scratching your RV’s delicate clear coat finish. The McKee's RV Safe Scrub Bug Sponge is 100% clear coat safe. Use it on paint, wheels, glass, chrome, plastic, and other hard surfaces that are in desperate need of a thorough cleaning.
The McKee's RV Safe Scrub Bug Sponge is constructed out of unique honey-comb foam, allowing the sponge to effectively remove bugs and grime without scratching your paint. At first the sponge feels coarse and stiff, making you question the bold claims about it being clear coat safe. After you let the sponge soak in a bucket of soapy water for 3-5 minutes, it softens up considerably, while retaining the bug-scrubbing ability of its honey-comb design. You can also use it by spraying the panel down with McKee's RV Bug Remover Lubricant.
The honey-comb design of the McKee's RV Safe Scrub Bug Sponge traps bugs and foreign particles as it removes them from your paint, ensuring the surface doesn’t get scratched. Dirt and grime is easily removed from the sponge, making it reusable hundreds or even thousands of times! The McKee's RV Safe Scrub Bug Sponge is so effective in its design and construction, you’ll wonder why it doesn’t cost more than $10!
The McKee's RV Safe Scrub Bug Sponge is easy to use. Simply allow it to soak in a bucket of warm soapy water 5 minutes prior to use, and gently rub the affected area. There is no need to apply pressure! The design of the sponge will do all the work for you. You can also use it without soap and water by spraying the panel down with McKee's RV Bug Remover Lubricant. This method is much easier if you're at an RV park.
Size - 5" x 3" x 3" each
On McKeesRV.com
McKee’s RV Bug Remover Lubricant
Use with our Safe Scrub Bug Sponge for quick, easy bug removal!
McKee’s RV Bug Remover Lubricant is a specially formulated spray-on cleaner that softens and aids in the removal of stubborn bug splatter. Bug Remover Lubricant provides ample lubrication for our bug cleaning sponge, helping prevent scratching and marring. Special enzymes attack the acidic byproducts of bug splatter, cleansing the surface to prevent long term damage like etching. Use on all exterior surfaces.
As soon as an insect splats against your front bumper, it immediately begins to break down. As the insect remains break down, enzymes are released that etch your clear coat, gel coat or fiberglass RV causing unsightly damage that cannot be undone. This is especially true for the infamous love bug, a common bug found in the South Eastern United States and throughout Florida. Spray McKee’s RV Bug Remover Lubricant onto the affected surfaces and wipe them clean with the McKee’s RV Safe Scrub Bug Sponge. Removing stubborn bug splatter has never been easier!
We’ve all heard of a special household remedy for removing bugs from your RV. We’ve tested them all through trial and error, and none of them work as well as our Safe Scrub Bug Sponge paired with McKee’s RV Bug Remover Lubricant. McKee’s RV Safe Scrub Bug Sponge uses its honey-comb design to essentially shave off bug splatter, leaving your RV clean and bug free.
Use the Safe Scrub by dunking it into your wash bucket, or better yet, simply spray McKee’s RV Bug Remover Lubricant onto the surface and then swipe the sponge over the area until it’s clean.
32 oz.
Made in USA
At McKeesRV.com
McKee’s RV Bug Remover Lubricant - 32 ounce
__________________
This one cleaner does the job of a dozen separate products!
McKee’s RV MPC Multi-Purpose Cleaner is a concentrated cleaner that removes grease and grime from virtually any surface inside or outside your RV. Use it to clean up everything from coffee spills to stubborn bug splatter. MPC is safe to use on leather, vinyl, engine compartments, wheels, tires, engine bays, chrome, stainless steel, fiberglass, and gel coat. This concentrated cleaner dilutes 1:5 for heavy duty cleaning and 1:10 for light duty cleaning.
Use to clean all exterior and interior surfaces!
100% safe on RV's with clear coated wheels
McKee’s RV MPC is strong enough to remove grease and grime from an engine bay, yet gentle enough to clean delicate leather upholstery. Why bother having a dozen dedicated cleaners and degreasers in your RV when you McKee’s RV MPC reduces the need to ONE? That was the primary goal during the development of McKee’s RV MPC.
McKee’s RV MPC is a concentrated cleaner that can be used full strength or diluted to meet your cleaning needs. Use it to clean the following surfaces:
• Engines
• Rubber roofs
• Wheels (painted, polished, or aluminum)
• Tires
• Leather
• Vinyl
• Carpet
• Bug splatter
• Road tar
McKee’s RV MPC doesn’t contain any caustic ingredients or damaging acids. Instead, MPC is formulated using water-based surfactants and 100% biodegradable degreasers. This enables MPC to clean various materials without leaving a film behind. To put it simply, if it can be cleaned with water then it can be cleaned with McKee’s RV MPC – Multi-Purpose Cleaner.
One product for all your cleaning needs...
32 oz.
Made in USA
At McKeesRV.com
McKee’s RV MPC – Multi-Purpose Cleaner - 32 ounce
Last Post: 08-31-2016, 11:07 AM
Last Post: 03-16-2016, 06:34 PM
Last Post: 02-20-2016, 01:17 PM
