Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Junior Member 05gpgtp's Avatar
    Mar 2013
    Peoria, IL
    44
    Customer wants me to do his boat. Help!!
    I have a customer that asked me to do his boat. He has a 2006 SeaDoo Sporster. It is 15'5"
    I have never worked with gel coat or done a boat like this. What steps do I need to do to accomplish a nice finish. I have not seen the boat yet, so I don't know exactly what it needs. I'm going to try and see it this weekend if possible after my other detail.
    Also he wants just the exterior (sides and bottom) done. Nothing on the interior. Can anyone help to recommend the process and or steps, brushes to use, type of polisher, cleaners????
    Also I have no idea what to charge to do this, since I don't do boats, he's agreed to purchase the cleaners, well I'll buy them and he'll pay me for those on top of the price to do it.
    Is it better to charge per hour or charger per foot? If i work on it for 10 hours at $35, then that's $250.00. If I do it per fot, then we're talking $308 ish at $25.00 per foot.
    I appreciate any help.
    Jun 2013
    Montreal, Quebec
    3,996
    Re: Customer wants me to do his boat. Help!!
    I am sure Mike will be able to give you some advice tomorrow.
    I have never done boats but I fairly certain you will need a rotary buffer to work on one. If memory serve they use something called Gelcoat on boats and it's very hard to polish with a DA. When I say hard I mean close to impossible.
    Again, Mike has done videos about boat restorations, so I am sure he can give you a few pointers. In the meantime you might want to check Youtube out for his (or other's) videos regarding boat polishing.
    Feb 2014
    Rochester MA
    2,627
    I would look into Autogeeks Marine polishes (Marine 31 Products). I will be doing a review on there Heavy cut cleaner wax, mildew remover, mildew guard. PM Nick@Autogeek as he just helped choose products for my father-in-laws 36' Intrepid.
    Yes, Ideally you would want to use a rotary buffer. Usually with a heavy cutting pad or wool pad as the gelcoat can be a bear to correct. The few boats I have done I charge by the foot to do the hull. Usually around 25-30$ a foot. Don't be afraid to charge because it's not easy work.
    IGL Authorized Coating/Kenzo Installer
    Final Inspection Auto Detailing- https://www.facebook.com/FinalInspection
    Jan 2015
    Ca
    I just did my dads 32' Trophy fishing boat.
    I used megs m105 on a megs microfiber cutting disc.
    Then followed with megs m205 on a lake country flat white pad with my griot garage polisher.
    And finally sealed it with Sonax PNS.
    It took me 30 hours to restore the hammered, heavy oxidized blue gel coat. It worked good and looks awesome now.
    Mar 2015
    North America
    115
    Is the boat in water? On blocks? Trailered? How are you going to adjust the boat to buff around the trailer/blocks?
    Without the interior you would be robbing the guy charging $25 per foot. The Seadoo is a small boat. The only reason some boats can command $25+ per foot, like Smokinss did with the 36ft Intrepid, is because of their depth, the seadoo is just a larger jetski. Boats like these: bass boats, fish and ski, etc.. it is way too much to charge anymore than $15-$20.
    The sides are only about 3ft deep and you should only buff to the natural water line/where the exterior color stops. The easiest thing to do would be to remove as much brightwork as you can, phillips head will work.
    As for products Megs 49 for the compound, then collinite, 303 aerospace, and a quality brightwork polish/enhancer. You cannot be gentile with gel coat, you have to be aggressive. Use a rotary with wool if you are comfortable. If not a DA with the most aggressive pad available, I have heard the orange peel denim pads work decently.
    Mar 2013
    Peoria, IL
    44
    I don't have a rotary and not going to buy one just for this. As far as what needs done, I'm going to go look at it tonight and take pictures. I've looked at them before and know they're small.
    Also it is on a trailer in his garage.Last time I did an aluminum bass boat, I jacked up the center with my jack and placed 2x6's under that area to buff the area over the trailer boards.
    If I can't do it, I can't do it. He's good either way, but I also don't want to pass up a job.
    As far as products to use, I'm looking at either Meguiars or Marine 31 only.
    Mar 2013
    Peoria, IL
    44
    Quote Originally Posted by 05gpgtp View Post
    meant to say $25 per foot
    But I will charge less if that seems more fair. I'm all about treating my customers right.
    Mar 2013
    Peoria, IL
    44
    ok so I went to look at the seadoo tonight. It's actually in really good shape. Only been in fresh water when used and always put back on trailer when done. So it hasn't sat in water for long periods. It looks to me that I could do a cleaner/wax one step on it. He's fine with the waterline up. I will still do the hull and bottom as much as I can but he wasn't too worried about that. Which one-step would you recommend? I don't think Meg's has a 1 step for Marine. I haven't looked into Marine 31 yet, but I do know pinnacle (from Mike's video) has a 1 step. OR again should I do a separate polish and separate wax. (I don't mind the work)
    I already told the customer it'd be $20 per foot, but if I'm doing a one step, maybe surprise him with a lower amount when he comes to pick it up. He's already agreed to the $20. Also wants me to do a little top side cleaning but nothing with inside areas.
    I've booked him for later in the year after he gets done playing with it on summer. He said he'll only be in a lake setting and not nasty rivers. There also is no algae or build up on the hull.
    Thank you for any other info you can provide. I do intend on using my Meg's DA, just depends on what cleaner I use and what pad to use?
    I have the Meg's burgundy soft buff 2.0 7" pad, Lakeside orange CCS pads, and Meg's MF pads.
    Apr 2012
    7,494
    That doesn't sound nearly enough, especially if you have to invest in new products to complete the job.
    2019 Nissan Rogue SL
  10. #10
    Mar 2013
    Peoria, IL
    44
    Customer is paying for the product and keeping the remaining.
  1. Video: First Training Boat Arrived - The REAL DEAL Boat Detailing Classes
    By Mike Phillips in forum 2-Day BOAT Detailing Classes - Info & Dates
    Last Post: 02-03-2020, 03:18 PM
  2. Pictures: How to wetsand a gel-coat boat - Boat Detailing Class - May, 2014
    By Mike Phillips in forum PICTURES: 2-Day BOAT Detailing Classes
    Last Post: 12-20-2019, 11:27 AM
  3. Secured one boat for the 2019 Boat Detailing Class! - Still need one more boat
    Last Post: 10-24-2018, 03:39 PM
  4. Replies: 14
    Last Post: 06-26-2011, 08:26 AM
  5. Customer wants me to do his boat ?
    By dbbrooks in forum Auto Detailing 101
    Last Post: 11-06-2010, 11:18 AM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
