Results 1 to 4 of 4
    Regular Member Hjfowler's Avatar
    May 2013
    Maryland
    174
    Car products on boats
    A few questions:
    1. Can you use car products in boats? (XMT 360 specifically)
    2. Is the gel coat the whole thickness of the smooth covering over the rest of the fiberglass? (About 1-2 mm thick)
    3? Can I use the same polishing and compounding pads on gel coat that I use on clear coat? (Orange LC pads)
    Thanks in advance. The boat I'm going to be working on isn't too bad, but there is some oxidation. I was thinking about starting with an actual compound, then a polish. Perhaps XMT.
    Regular Member Theraven's Avatar
    Nov 2012
    110
    You can use car products on boats, if there's med-heavy oxidation and or decent amout of swirls/scratches a good marine compound is needed with wool/rotary. You can you the same pads for cars/clear coat on gel, as usual start with wool(if needed) and finish with foam, depending on the condition. Yes the gelcoat is the whole thickness over the glass.
    Super Member brondondolon's Avatar
    Nov 2013
    1,254
    Car products will work but marine products will work a whole lot faster.
    Sent from my HTC6435LVW using AG Online
    Nov 2012
    110
    Tried some 3m Auto advance rubbing compound (i bought at Walmart) , on a old Bertram, It worked great, cut fast, and it actually polishes the surface ,unlike the crap marine compound my boss uses, which is really greasy, low/poor cutting ability, and it seems like it just burnishes the surface rather than attempting to truly polish it. The stuff will gum up your pads like no tomorrow. I've had really good results with 3m and Megs car products on boats, haven't experiment with anything else really.
  1. What about BOATS?
    By Joseph Rogers in forum Auto Detailing 101
    Last Post: 04-26-2014, 12:09 AM
  2. Car products on boats
    By Hjfowler in forum Ask your detailing questions!
    Last Post: 04-10-2014, 03:27 PM
  3. Boats and Cars and autogeek products
    By ProMoDe in forum Product Reviews
    Last Post: 10-06-2011, 10:23 PM
  4. Boats , boats , boats
    By time-2-shine in forum Auto Detailing 101
    Last Post: 01-15-2008, 10:18 PM
  5. Optimum Products on Boats?
    By Nuke33 in forum Auto Detailing 101
    Last Post: 03-27-2007, 02:32 PM
