Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    May 2015
    New-ish boat combo?: Flex 3401 + Rupes Blue Coarse Foam pad + Captain’s One-Step + Captain's Boat Coating?
    Hello Mike (and others)!
    I am looking to polish a 1-year old 30ft. Grady White with light-blue colored gelcoat. As the boat is only a year old, the gelcoat is in visibly great shape and doesn't need heavy cutting. There are a few superficial bumper/buoy scuffs, but nothing major at all. I was looking to use my Flex 3401 with a Rupes Blue Coarse Foam pad and the Marine 31 Captain's One-Step to do the polish.
    I have a few questions:
    1. Does this seem like a good combo for a relatively new boat?
    2. Is the Rupes Blue Foam pad too aggressive for this to be a one-step process and will I have to follow it up with a softer pad?
    3. What sealer would you recommend? I'm looking at the Marine 31 Captain's Boat Coating with UV50. Will I need to wipe the boat down to remove oils from the Captain's One-Step prior to using the Boat Coating?
    The boat sits in the water from April - October in New Jersey so I'm looking for a durable sealer that will last as long.
    Thanks in advance!
    Last edited by pbalias; 03-21-2018 at 06:52 PM. Reason: accidentally submitted before finishing post
    May 2015
    Re: Flex 3401 + Rupes Blue Coarse Foam pad + Captain’s One-Step + Captain's Boat Coating?
    Mike?
    Newbie Member BigMikeMD's Avatar
    Dec 2017
    Upper Bay
    Quote Originally Posted by pbalias View Post
    Mike?
    You should definitely get Mike's boat detailing book. It has a ton of detail, photos and options for exterior & interior work.
    I'm planning on a similar combo (flex 3401 + blue coarse rupes pads) on my boat, less than a year old and minimal oxidation after first summer on the water in Maryland.
    Going to try the All in One polish & wax from Marine 31 at the start of our season, and use the wax + sealant to keep it protected.
    Sent from my SM-N950U using Tapatalk
    Dec 2017
    Upper Bay
    Re: New-ish boat combo?: Flex 3401 + Rupes Blue Coarse Foam pad + Captain’s One-Step + Captain's Boat Coating?
    I had in my notes that GTechniq (?) makes a good marine coating. Think they used this in the boat class.
    Sorry I missed your first post - I’m not behind my computer so hard to type but “yes” that’s one of the combos I find works great and I show on my class.
    FKEX 3401 - RUPES Coarse Blue Fosm Pad - Captains Compound
    Then seal.
    Not too aggressive - gel coats don’t like soft foam pads when abrading.
    Will type more tomorrow.
    May 2015
    Thanks for the response Mike and the link...answers some questions. Sounds like BigMikeMD and I are in the same situation.
    Question: Will the Flex 3401 with the Rupes blue foam cutting pad + the Marine 31 Captain's One-Step have enough cutting power to get rid of mild-light oxidation on a 1-year old boat, or will it only take out the holograms from a rotary? I wan't planning on using a rotary and was hoping the Flex 3401 had the cutting power.
    Great question and it shows me you actually read the section instead of scanning it, thank you.
    I hate to give fluffy answers but you won’t know until you do a Test Spot. I’ve experienced super hard gel-coats and super soft gel-coats. Pigment can affect hardness but so can the resin a particular boat manufacturer uses, so you won’t know until you do some testing.
    Still can’t type much, on my phone as were driving to Orlando.
    Car Detailing Tech Session & Demo at the Ace Café in Orlando!
  10. #10
    May 2015
    That's a fair reply Mike and totally makes sense, thank you. I'm going to make an attempt with the 3401 and a Purple Foamed Wool pad and see what happens. If it cuts like I need it to, I'll follow it up with a Rupes blue foam then seal. Hopefully that's all it takes.
  1. Foam Pads for Marine 31 Captain's One Step Compound & Polish?
    By CC268 in forum Boat & Marine Craft Detailing
    Last Post: 07-30-2020, 07:52 PM
  2. Review: Marine 31 Gel Coat Prep Spray & Captain’s Boat Coating with UV50
    Last Post: 12-17-2019, 12:02 PM
  3. Top coating Marine 31 Captain’s Boat Coating
    By belairbubba in forum Marine31 Boating Products
    Last Post: 10-06-2019, 05:22 PM
  4. Marine 31 Captain's Boat Coating w/UV50
    By Andy B. Cool in forum Product Reviews
    Last Post: 08-18-2015, 10:06 PM
  5. *NEW* Marine 31 Captain's Boat Coating with UV50
    Last Post: 05-01-2015, 09:27 AM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
