Results 1 to 2 of 2
    May 2017
    Removing Swirls from gelcoat
    During the day with the sun out the boat looks fine. the hull color is a pale blue, it has a decent refection and is smooth and clean but put the spot light on it and you really see all the swirls. My guess is if I can remove the swirls I should be able to get the mirror like reflection Ive been looking for. What are the steps you would take to begin to correct these swirls? I assume cut with wool pad, but do you polish with a wool pad or something else? Same goes with waxing stick with wool or something else?
    heres what I am working with
    Super Member Trip's Avatar
    Feb 2016
    Windsor Ontario Canada
    310
    Re: Removing Swirls from gelcoat
    My boat looked the similar when I first picked it up. Looked shiny but once under light you could tell it was a quick rotary buff to make it look presentable for sale. I spent a bit of time using a Dewalt 849 with a wool pad and Marine 31 product. Ended up finishing with a black foam pad and the holograms had disappeared. I only have 16 feet of boat to deal with .
    Sent from my SM-G930W8 using Autogeekonline mobile app
  1. Removing Deteriorated Duct Tape from Gelcoat
    By Linda Fields in forum Ask your detailing questions!
    Last Post: 10-18-2019, 10:40 PM
  2. Swirls in gelcoat
    By 58LesPaul in forum Boat & Marine Craft Detailing
    Last Post: 03-17-2018, 09:39 PM
  3. Swirls on RV gelcoat--Britemax hard to remove
    By Roryq in forum RV & Motorhome Detailing
    Last Post: 05-18-2017, 11:29 AM
  4. Removing Light Swirl Marks on GelCoat
    By davewfo in forum Boat & Marine Craft Detailing
    Last Post: 04-27-2017, 11:49 AM
  5. Removing Undercoating on Gelcoat?
    By sunburn in forum Boat & Marine Craft Detailing
    Last Post: 09-13-2016, 11:13 PM
