Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    Feb 2013
    662
    Re: New to Boat Detailing - Polishing with a GG6?
    The polishes and cleaner/waxes you listed are on the medium to light cut side of aggressiveness.
    If the oxidation isn't too bad they will work. If the oxidation is severe then you're going to need a more aggressive product plus an aggressive pad.
    You posted this,
    Lucky for your friend.
    Yes. And the better the condition the easier it will be with this category of tool.
    Stick with the yellow and orange pads with cleaner/waxes and the polishing and waxing pads for NON cleaning cleaner/waxes
    The most important tidbit of help I can offer is to START by doing some TESTING.
    Dial in a process that makes one small section look GREAT!
    If you can make one small section look great then the same process will work over the rest of the boat.
    Don't make the mistake of buffing out an entire boat without testing first only to find out what you "did" didn't work.
    Thanks a lot! This boat has no oxidation whatsoever, so we would be polishing it simply to "perfect" it and then protect it. If I was working on a boat with bad oxidation I would probably want to by myself a Flex 3401...
    I was thinking about going with the Marine 31 Captain’s One-Step Compound & Polish, but that would be overly aggressive for this boat and it sounds like I have products that will do the job anyways. I figure a good coat of Collinite 845 would do the trick for the LSP.
    Feb 2013
    662
    Mike - Why do you suggest using the least aggressive product (cleaners) with the most aggressive pads?
  3. #13
    Sep 2015
    6,281
    Quote Originally Posted by CC268 View Post
    Any suggestion on a good compound?
    #49 megs marine product.
  4. #14
    Sep 2015
    6,281
    Pics would great.
  5. #15
    Sep 2015
    6,281
    Or m44
  6. #16
    Feb 2013
    662
    Quote Originally Posted by GSKR View Post
    Pics would great.
    My buddies boat is a 2013 and in great shape so most of this is overkill anyhow, but I like to be prepared in case something pops up
  7. #17
    Sep 2015
    6,281
    Just a thought.marine 31 gelcoat and color restore.If it's in great condition auto products will suffice.
  8. #18
    Feb 2013
    662
    Yea...I've heard actually good things about HD Speed on boats and that may be a good AIO solution.
  9. #19
    Sep 2015
    6,281
    The downside to HD is the durability is just not there,maybe top it with a good sealant.Double the work but it will be done right and you will be happy.
  10. #20
    Feb 2013
    662
    Yea HD Speed with Collinite 845 seems like a good combo
  1. Replies: 10
    Last Post: 08-12-2020, 03:12 PM
  2. Replies: 11
    Last Post: 03-02-2020, 10:05 AM
  3. Replies: 0
    Last Post: 02-17-2020, 01:20 PM
  4. Secured one boat for the 2019 Boat Detailing Class! - Still need one more boat
    By Mike Phillips in forum 2-Day BOAT Detailing Classes - Info & Dates
    Last Post: 10-24-2018, 03:39 PM
  5. Replies: 25
    Last Post: 07-11-2011, 06:58 AM
