The polishes and cleaner/waxes you listed are on the medium to light cut side of aggressiveness.
If the oxidation isn't too bad they will work. If the oxidation is severe then you're going to need a more aggressive product plus an aggressive pad.
You posted this,
Lucky for your friend.
Yes. And the better the condition the easier it will be with this category of tool.
Stick with the yellow and orange pads with cleaner/waxes and the polishing and waxing pads for NON cleaning cleaner/waxes
The most important tidbit of help I can offer is to START by doing some TESTING.
Dial in a process that makes one small section look GREAT!
If you can make one small section look great then the same process will work over the rest of the boat.
Don't make the mistake of buffing out an entire boat without testing first only to find out what you "did" didn't work.
