Results 11 to 20 of 33
    Super Member asap2stacks's Avatar
    Mar 2016
    Maryland
    551
    Re: Can my boats gel coat be restored
    RCan my boats gel coat be restored-imageuploadedbyagonline1469049872-263599-jpgCan my boats gel coat be restored-imageuploadedbyagonline1469049886-877901-jpgCan my boats gel coat be restored-imageuploadedbyagonline1469049902-548048-jpgCan my boats gel coat be restored-imageuploadedbyagonline1469049916-965709-jpgCan my boats gel coat be restored-imageuploadedbyagonline1469049932-775816-jpg
    Mar 2016
    Maryland
    551
    I'm having problems with just the back part of the boat 1000 grit wet sand and compounded with rotary and still looks like this any suggestions?
    Can my boats gel coat be restored-imageuploadedbyagonline1469050180-484927-jpg
  3. #13
    Super Member FrankS's Avatar
    Jul 2013
    West Palm Beach, FL
    1,560
    The gel coat may be too far gone.
    You could try doing test a spot with 800 dry, 1000 wet, compound, polish.
    I know of some who have gone to 400 dry and then worked their way up.
    To remove the 1000 grit marks, you're going to need an aggressive compound than can remove 800 grit marks (there are some out there for boats), with rotary and wool pad.
    If you don't have the aggressive compound then use 1500 or 2000 grit after the 1000 grit and work your way up until the sanding marks can be compounded out.
  4. #14
    Mar 2016
    Maryland
    551
    Alright I just don't want to burn thro the gel coat with 600 it seems like a lot even 800 does... How will you know if you burnt thro it?
  5. #15
    Jul 2013
    West Palm Beach, FL
    1,560
    Quote Originally Posted by asap2stacks View Post
    Gel coat is much thicker than the clear coat on a car and you will have much more to work with.
    I know of some professional boat detailers who regularly start with 800 dry on very oxidized high end boats and sometimes go even lower.
    You can always try a small section and see how it goes.
    If you don't get an answer here you can check out the Marine 31 forum or join some boat detailer groups on FB (I'm a member of a couple of them) and post the same question.
  6. #16
    Super Member rmagnus's Avatar
    May 2011
    SoCal
    1,446
    That looks way better. I agree with a test spot for the back quarter. You may only be able to get 50-75% improvement. Wait a minute isn't the back quarter going to be under the water? Go boating!
    Semper Fi
    Ralph
  7. #17
    Mar 2016
    Maryland
    551
    I might try 800 grit tomorrow to see if it can improve even more
  8. #18
    Mar 2016
    Maryland
    551
    Can my boats gel coat be restored-imageuploadedbyagonline1469152213-637694-jpg
  9. #19
    May 2011
    SoCal
    1,446
    Job well done. Pretty amazing what some elbow grease an do. Enjoy it.
    Semper Fi
    Ralph
  10. #20
    Jul 2013
    West Palm Beach, FL
    1,560
    What steps did you finally take?
  1. Holograms in gel-coat boats by Mike Phillips
    By Mike Phillips in forum 2-Day BOAT Detailing Classes - Info & Dates
    Last Post: 01-28-2021, 01:38 PM
  2. Boats, Boats and more Boats
    By attention2detaillhc in forum Show N' Shine
    Last Post: 04-17-2017, 02:31 PM
  3. 2 Boats Wanted - Black Gel-Coat Boat & Pontoon Boat
    Last Post: 05-05-2015, 04:09 PM
  4. Replies: 12
    Last Post: 09-17-2013, 09:24 PM
  5. Replies: 14
    Last Post: 06-24-2012, 11:36 AM
