Re: Bf spray sealant question
Mckees SiO2 soap is a good idea.
Just as an FYI, McKee's SiO2 wash leaves no protection behind. It leaves gloss enhancers to brighten up the paint without clogging a coated surface.
If you are just looking for a drying aid or quick detailer just get yourself some EcH2O. Then use the spray sealant periodically.
For BLACKFIRE SIO2 SPRAY SEALANT does glass get stuck in the towels? Do they have to be cleaned before reuse etc.?
Originally Posted by
tim500
I’ve had no issues with towels used with BF SiO2 Spray, but I put all my used towels in a bucket of MF cleaner right after use, let them sit then rinse them out, they will later be washed together in the washing machine.
Even if you don’t put them in cleaner right away, I haven’t heard of it ruining towels yet.
what's better to put on after ion sealant this or BF sio2?
I recently applied two coats of Jescar Power Lock Plus Polymer Sealant (Menzerna) to a clean and clayed surface. I have a bottle of Backfire Wet Diamond Polymer Spray and wondering if that is compatible with Power Lock? I believe they are similar compounds?? Would use the BFWD on occasion for a fresh up and preservation of the Power Lock after a washing.
Will this bead water? How does it compare to CarPro exlir?
Personally don't understand why you'd top BF SiO2 spray. It's a spray sealant, why not "top" it with itself? Or use a different spray product altogether.
I had sonus ion put on my car. I had to have water spots removed professionally. I didn’t want to use sio2 over ion.
MagsH2
In the same boat. Got a coat of BF spray SiO2. I have synthetic spray wax as well and was going to use that weekly as my after wash or QD. Can I then put on another coat of spray SiO2 to jazz up the shine and slickness at any time or will there be any bonding issues?
how do you compare the products, si02 vs synthetic spray?
