Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Nov 2015
    Los Angeles, California
    13,830
    Re: Applying Blackfire wet diamond
    Quote Originally Posted by ronkh57 View Post
    If dust settles on it, it could cause marring as you remove the excess sealant.
    This👆🏽
    Super Member 07gtcs's Avatar
    Feb 2012
    693
    It is SOOOO easy to put on take off, you won't lose much sleep by wiping off right after you apply it.
  3. #13
    Apr 2012
    7,494
    Directions:
    For best results clay the paint first with BLACKFIRE Poly Clay and polish with BLACKFIRE Gloss Enhancing Polish or BLACKFIRE SRC Finishing Polish.
    Hand Application: Always use on a cool surface out of direct sunlight. Apply a quarter size amount of product on a dry applicator pad and wipe on the surface using small, circular motions. Allow Wet Diamond All Finish Paint Protection to dry before buffing. Buff haze with a clean Cobra microfiber towel.
    Machine Application: Apply BLACKFIRE Wet Diamond All Finish Paint Protection using a finishing pad or wax pad on an orbital polisher, such as the FLEX XC 3401 VRG Orbital Polisher. Work on a small area, about 24 to 24 inches square, out of direct sunlight. Apply two 6 to 8 inch lines of All Finish Paint Protection directly onto the surface. With the machine off, spread the sealant over the surface using the dry foam pad. This coats the foam pad and the paint with sealant. Place the pad on the paint and turn the machine on. Set the speed dial on the polisher between 3 and 4. Work the pad over the surface in a back-and-forth motion and then an up-and-down motion. Apply until the sealant starts to dry. Cover one section of the vehicle at a time (i.e. the hood, a door, fender, etc.) Allow a haze to form. Hand buff to a brilliant shine with a Cobra Microfiber Towel.
    2019 Nissan Rogue SL
  4. #14
    Oct 2009
    493
    Yes you can let it sit until 2023 if you would like.
  5. #15
    Apr 2016
    Thanks guys I saw how easy it came off and took it off last night.
  6. #16
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    How does it look?
  1. Need some help with applying PBL Diamond coating
    By emmjay in forum Ask your detailing questions!
    Last Post: 06-07-2016, 08:38 AM
  2. Blackfire Wet Diamond vs. Blackfire Crystal Seal
    By Jmoran in forum Auto Detailing 101
    Last Post: 12-17-2015, 03:17 PM
  3. Blackfire wet diamond
    By Lightning04 in forum Ask your detailing questions!
    Last Post: 12-16-2013, 01:37 AM
  4. Need some help with removing old wax & applying Blackfire
    By thebouncer in forum Auto Detailing 101
    Last Post: 06-30-2012, 03:09 AM
  5. M21 vs. Blackfire Wet Diamond?
    By truckbutt in forum Auto Detailing 101
    Last Post: 08-04-2011, 11:31 PM
