Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    Regular Member MonoPed's Avatar
    Nov 2010
    Hernando, FL
    163
    Re: New How-To Segment on Motorhead Garage - February 13th and 14th
    Thanks, Mike!
    Brian Fowler, Hernando, FL
    2008 Mustang Pony Package
  2. #22
    Re: Products used on Motorhead Garage Episode 1107
    How to use a DA Polisher to Remover Oxidation
    The technique used for applying the Pinnacle Advanced Swirl Remover and the Pinnacle Advanced Finishing Polish is called doing a Section Pass, see this video...
    Show Car Garage Video: How-To do a "Section Pass" when Machine Polishing with a DA Polisher
    Here's how to do a "Section Pass" when trying to remove swirls, scratches and other below surface paint defects.
    How to do a Section Pass
    When talking about machine polishing on discussion forums or even in detailing classes, the below questions always comes up,
    • What's a pass?
    • How many passes do I make?
    • What's a section pass?
    The definition of a pass
    There are two definitions of the word pass as it relates to machine polishing with any type of machine.
    Single Pass
    A single pass is just that. It's when you move the polisher from one side of the section you're buffing to the other side of the section you're buffing. That's a single pass.
    Section Pass
    A section pass is when you move the polisher back and forth, or front to back with enough single overlapping passes to cover the entire section one time. That's a section pass.
    In most cases if you're removing any substantial below surface defects you're going to make 6-8 section passes to the section you’re working before you either feel comfortable you've removed the defects or you're at the end of the buffing cycle for the product you're using.
    Buffing Cycle
    The buffing cycle is the amount of time you are able to work the product before the abrasives have broken down, (if you’re using a product that uses diminishing abrasives), and/or the product begins to dry and you lose the lubricating features of the product. Different products have different buffing cycles depending upon the type of abrasives used in the formula and the different ingredients used to suspend the abrasives and provide lubrication.
    Factors that affect the buffing cycle include,
    • Ambient temperature
    • Surface temperature
    • Size of work area
    • Type of machine
    • Type of pad material
    • Humidity
    • Wind or air flow surrounding the car
    • Amount of product used
    • Technique
    Wet buffing technique
    Most compounds and polishes should be used so that there is enough product on the surface to maintain a wet film while the product is being worked. The wetness of the product is lubricating the paint as the abrasives abrade the paint and cushion or buffer the abrading action so the abrasives don’t simply scour the finish leaving behind swirls and scratches.
    Dry Buffing Technique - Buffing to a dry buff
    There are some products on the market where the manufacture recommends buffing the product until it dries. As the product dries you’ll tend to see some dusting as the product residue becomes a powder and the paint will have a hard, dry shine to it.
    Although some manufactures recommend this, it’s important to understand what’s taking place at the surface level as you buff to a dry buff. As the product dries, in essence you are losing the lubricating features of the product and as this happens friction and heat will increase. As friction and heat increases, so does the risk of micro-marring the paint or instilling swirls either by the product residue or the pad material and/or a combination of both.
    While we trust that the manufacture knows their products best, when we take a close look at what it means to buff on a delicate surface like an automotive clear coat, it doesn’t make sense to run a buffing pad on top of the paint without some kind of wet film to lubricate the paint at the same time. We always recommend that you follow the manufacturer's recommendations and use your own judgment.
    Everyone new to buffing wants to be told some easily identifiable sign that they can use to tell when it's time to stop buffing and it's not that simple, so here's an indicator I've always used and taught to others,
    Wet film behind your path-of-travel
    As you're making a single pass with the polisher, the paint behind the path of travel of the buffer should have a visible wet film on it. If the paint behind the pad is dry and shiny, you've run out of lubrication and you're dry buffing. Turn the polisher off. Wipe the residue off and inspect using a Swirl Finder Light to make sure you didn't dull or mar the paint, you usually won't cause any harm, but pay attention when your running the polisher and don't buff to a dry buff. If you do, you can quickly re-polish that section by cleaning your pad and adding a little fresh product and making a few new section passes.
    UMR
    Remember, in most cases the goal is UMR or Uniform Material Removal. The reason for this is so that you remove an equal amount of paint over each section and in turn over the entire car. In order to do this you need a method that you can control and duplicate and for most people following a back and forth, side-to-side pattern works because it’s easy to remember, easy to do and easy to duplicate.
  3. #23
    In April there will be 3 new "How-To" segments airing on TV and we'll announce these as the dates get closer.
    1964 GTO Convertible...
    And a classic, 1955 Chevy Pickup...
    Part of the job...
  4. #24
    Here's a recent thread on Microfiber Gloves...
    Increase Your Grip Strength with Microfiber Gloves
  5. #25
    Junior Member Barry Theal's Avatar
    Jul 2010
    96
    Mike what are these people doing to you? OH know make up to detail cars. That 55 chevy pick up really looks like a fun task. Have fun with it.
    http://www.autogeekonline.net/galler...rojectx003.jpg
  6. #26
    Quote Originally Posted by Barry Theal View Post
    To date, none of the other TV studio sets I've worked on have air conditioning and most of the shoots have been during warm or hot weather, so with the extra lights on the set it gets pretty hot. On this show, Sheila was our make-up artist and she just makes sure the host and all his guest are ready to go before filming their segments.
    Max had air-conditioning installed for our studio and we can crank the temperature down to 68 degrees if we want and I can't tell you how nice that is compared to these other studios. I know when Matt Steele was here he appreciated it and so did the Camera Crew, Director, Engineer and Producer from Masters TV.
    On Two Guys Garage they also have a Make-up Artist that takes care of Bryan Fuller and Kevin Byrd and their guests.
    It's just part of the job...
    I'm going to post a thread about this new TV show today...
    Motorhead Garage Studio
    Two Guys Garage Studio
  7. #27
    Re: Motorhead Garage - Machine Polishing with Pinnacle - Episode 7
    ***Update***
    Added the video from this TV show to the first post on the first page of this thread.
  1. Replies: 4
    Last Post: 08-25-2017, 09:34 AM
  2. Watch Motorhead Garage this Sunday and Monday!
    By Mike Phillips in forum What's In The Garage?
    Last Post: 11-28-2011, 03:59 PM
  3. My Classic Car - Machine Polishing with Pinnacle - Episode 14
    By Nick McKees37 in forum Autogeek on Velocity Channel TV
    Last Post: 05-24-2011, 09:07 PM
  4. My Classic Car - Machine Polishing with Wolfgang - Episode 6
    By Mike Phillips in forum Autogeek on Velocity Channel TV
    Last Post: 04-12-2011, 12:04 PM
  5. Motorhead Garage - Machine Polishing with Pinnacle - Episode 2
    Last Post: 08-29-2010, 07:48 AM
