Good Microfiber Pads?
Getting ready to order some new pads, and wanted to know what everyone is using.
I have been using the Rupes Microfiber Pads, but been hearing good things about the Meguiars pads.
Anyway whats everyone using?
Re: Good Microfiber Pads?
Meg's via Rupes 15
I love the megs pads. I have a gg6, but am using the 5" kit. It works quick and finishes well on the cars I have done.
I use the Rupes too, as well as the Lake Country Ultra Fiber pads. The Ultra Fiber I consider more durable than the Rupes pads, but I'm still dialing in my technique with them (the rupes pads).
I read something where Todd Helme recommended using speed 3 or 4, as to not mat down the fibers. I did that with a new pad, and Menzerna FG400 and the pad looked new after I washed it. I also cleaned the pad with the Duetto off with the pad conditioning brush. When I use the Rupes Zephyr polish, it gets stuck in the pad, and doesn't even want to wash off.
I'll be trying that technique with Meguiar's M105, M101, and D300. I seem to prefer those with Microfiber pads.
I did a Nitro a couple weeks ago with LC ultra fiber + Megs D300 on a PC, and they tore through the swirls and scratches.
I was looking at ordering the Meguiar's DMC6 6" Cutting pads.
Are you guys just using the MF Cutting pads with a more gritty compound then finishing up with a foam pad and less gritty compound?
Like i have been using wolf gang would and would i use Uber w/ MF Cutting pad then go to Wolfgang swirl remover w/ foam pad?
hi everyone.. can anyone help me in this .. i am new in detailing service.. which pad is better ..Lake Country HD Orbital Foam Pads or Lake Country CCS pad
Griot's Fast Cut MF pads.
Meg's Microfiber Cutting pads are a must! Also, check out their new burgundy foam cutting disc that leaves an AMAZING! finish.
If you're using a Rupes with a 5" backing plate, call Kevin Brown and order a custom cut backing plate to fit the DMC/DMF 5
That's what I've been doing.
Cut with the blue Rupes mf pad, polish with the yellow, seal with the white.
With the PC I start the compounding process with the green hex logic. If that isn't getting it, I switch to the microfiber. With the Flex 3401, I stay with foam. Again, if the green isn't doing it, I'll put the yellow on. I've never had to do that though.
By coupe07 in forum Wool & Foam Buffing Pads
Last Post: 05-15-2015, 08:21 PM
By DP 08 GXP in forum Wet-Sanding, Cutting & Buffing
Last Post: 09-11-2013, 07:40 AM
Last Post: 05-24-2012, 06:33 PM
By SalFoges in forum Auto Detailing 101
Last Post: 04-21-2012, 06:49 PM
