Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Apr 2015
    best da/polisher for lens corrections?
    Hi,
    Just wondering what everyone's favorite model da/polished is for doing headlight lens corrections?
    Thanks,
    Chad
    Jun 2013
    Frederick, MD
    353
    Re: best da/polisher for lens corrections?
    I've used a GG 3" with success, but I generally use the HF DA. Any DA (PC, GG 6", Rupes Mini/Duetto) that can take a 3" backing plate works great.
    One of the 3m kits comes with a backing plate for a drill, that works really great - especially the compounding step. But I used a cheap drill that was bad at maintaining speed below full throttle and it took me longer than with a DA.
    Just make sure you use a foam interface between the pad and sand paper when sanding.
    Edit:
    I use the purple foamed wool pad for the compounding step and it gets out 3,000 grit marks in seconds. Microfiber pads work too. For polishing it's up to you.
    Super Member Firehouse Mike's Avatar
    Feb 2014
    Olympia, WA
    478
    I recently went to a Ryobi right angle cordless drill
    Ryobi 18-Volt ONE+ 3/8 in. Right Angle Drill (Tool Only)-P241 - The Home Depot
    With the Megs 3" drill adapter plate, it acts like a mini rotary ( 1100 rpm ). Works great for sanding or cutting with M105 on the lens. I switch over to a impact drill for higher speed for the finial polish.
    Ryobi 18-Volt One+ Impact Driver (Tool-Only)-P236 - The Home Depot
    Seems to be a great system so far, and are much easier to handle when working on lenses that have several angles / weird contours.
    Mike
    Super Member VISITOR's Avatar
    May 2007
    9,729
    if you don't already have a DA, pick up a GG6 and both the DA 3.5" (for use with 4" pads) and 5" (for use with 5.5" pads) backing plates which will allow you to work on just about every inch of your vehicle...
    Griots Garage 6 Inch Random Orbital Polisher
    3.5" Dual Action Flexible Backing Plate- porter cable 7424XP hook and loop backing plate 3.5 inch.
    lake country 5 inch backing plate, 5 inch backin plate, 5 inch hook and loop backing plate
    i am the jump starter.
    Super Member Mike Honcho's Avatar
    Apr 2015
    Atlanta
    1,264
    After getting the above stuff, what products do y'all generally use? M105 and M205?
    Mike Honcho
    Super Member Ryan509's Avatar
    Jun 2014
    Renfrew County, Ontario
    200
    I personally like menzerna products as they finish out amazingly for the price and a little goes a long way with them. Plus FG400 can be used as a 1 step if you wanted. Then all you have to do is seal.
    I personally use Menzerna FG400 & SF4000 then topped with a sealant. But Will be switching to coatings soon
    Super Member mc2hill's Avatar
    Feb 2009
    Orlando
    553
    Quote Originally Posted by Ryan509 View Post
    I have recently switched from M105 to FG400 too. Much less dust.
    I use a corded drill for the compound and the polish.
    Apr 2015
    Atlanta
    1,264
    Which sealant/coating do you use?
    Mike Honcho
    Jun 2014
    200
    currently just using BF wet diamond. But will be switching to the new blackfire coating soon
  10. #10
    Apr 2015
    Currently I have a gg6 w/3,5&6" backing plates and a Rupes 15 w/5" mequiars microfiber cutting pads and a handful of different foam pads. For polished I have some menzerna fg400 and sonax perfect finish. For sealant I was thinking optilens.
    I could correct my lenses with this combination but I think I will be doing a friends lenses that are pretty cloudy. I'll use the gg6 with 3" backing plate.
    Do you all make 3" circular sanding discs? Or can you buy pre cut discs in 1,2,3000 grit ?
    If I upgraded the gg6 would you all go with flex pe8 or the Rupes 75?
    Chad
  1. One Step Corrections
    By CavScout10 in forum Auto Detailing 101
    Last Post: 05-19-2016, 03:10 AM
  2. How often between corrections?
    By Farmingdales Finest in forum Auto Detailing 101
    Last Post: 04-17-2016, 08:49 AM
  3. Suggestions for corrections need
    By MorphiousGX in forum Auto Detailing 101
    Last Post: 04-26-2014, 08:01 PM
  4. Spotty Corrections
    By muddy in forum Ask your detailing questions!
    Last Post: 04-27-2010, 10:11 AM
  5. PR: Wolfgang Plastik Lens Cleaner and Wolfgang Plastik Lens Glaze
    By sullysdetailing in forum Product Reviews
    Last Post: 12-02-2009, 11:04 AM
