05-25-2018, 07:15 PM
#131
Re: SunJoe SPX3000 longer hose?
Originally Posted by
CaptN D
You can but if your like me you’ll probably want for a longer hose. If I could do it again I’d get Sun Joes offering w out the built in reel so that getting a longer hose for like the spray gun isn’t gonna be a PITA!
Have you found a solution? I'm actually considering that option as well. But, would also need a longer pressure washer hose, which seems like its gonna be difficult
05-25-2018, 08:00 PM
#132
Just a long shot for most, I'd think. But I am lucky enough to have a company near me that is a high-end welding company that also does all forms of hydraulic repair.
They can form & fit any length PW hose you desire. I've had them replace countless PW hoses for me when I worked at the marina.
Just throwing it out there..........
05-25-2018, 10:01 PM
#133
05-26-2018, 12:16 PM
#134
CaptN D
Any Update on this?
Lakeland -Tampa - St Pete - Clearwater - Sarasota
Boats / Auto / Trucks / RVs
863-738-8336 Follow us on
Instagram
05-26-2018, 08:46 PM
#135
ShinyGC
its a very stiff hose with non standard fittings... In my opinion id buy a new hose all together and just adapt it to the PW.
I got mine from Kleenrite online (50' single wire rubber hose) and bought an m22/15mm to m22/14mm adapter for the back of the unit. Done.
Where did you find at female m22 15mm to m22 14mm male adapter? I cannot seem to locate anywhere. Thanks!
05-26-2018, 08:50 PM
#136
estcstm3
This one?
Instagram
05-26-2018, 09:17 PM
#137
jolo
This one?
possibly, i was expecting to see it attached to the power washer base though? My throughts are just getting a new standard 14mm M22 hose (something like the uberflex hose on amazon which is 14mm M22). To get that hose to fit i would need to put a 15mm M22 femal to 14mm m22 maie adapter on the pressure washer unit, then i can just hook the hose up and put on any MTM hydro pistol foamer without any other non standard type adapters.
Am i missing something?
05-26-2018, 09:21 PM
#138
Instagram
#139
disclaimer i dont own a sun joe i have a genarac gas pressure washer, and i taking a second look at the pictures im assuming the hose connects to a "male" m22 connection on the unit and the hose ends are female m22 right?
05-26-2018, 09:26 PM
#140
You need M22 15mm Female to fit SunJoe pressure hose then whatever you want on the other side. I did 3/8 to install quick coupler.
Instagram
