5.5" or 6.5" hd foam pads?
Which size do you prefer and why? and do they both fit on a 4 3/4" Lc flexible backing plate. Its for the makita rotary. Im probably gonna get the three pack I'm thinking the hydro tech ones are the way to go.
Re: 5.5" or 6.5" hd foam pads?
Its nice to have both size pads but the smaller pads are easier to handle where as the larger ones are nicer for horizontal surfaces .
Both pads are probably ok on your backing plate but the 61/2 may have a tad bit more overhang then ideal.I dont ever use 6 1/2 pads so maybe some one else who does will post.
The hydro tech pads are really nice but you must not over saturate them or use them damp/wet or they can shred and not last long at all.Also they take longer to dry after you clean them .
4 3/4" backing plate may be fine with 5.5" pads.
You need 6" plate for 6.5" pads.
Flex 3401 & PE14
I would get the 7/8 pads vs the 1.25 inch .
I made the mistake of getting the thicker pads and found them harder to controle on the rotary.
By Whitewater25 in forum Wool & Foam Buffing Pads
Last Post: 04-25-2016, 10:41 AM
By dennis hiip in forum Auto Detailing 101
Last Post: 09-16-2014, 05:01 PM
By Theraven in forum Auto Detailing 101
Last Post: 09-01-2013, 11:18 AM
Last Post: 08-31-2011, 07:48 AM
