Microfiber and Pad detergent
Wasup Guys, Just want to know from you guys if you use dedicated MF detergents and if yes what can you recommend? Thanks!
Re: Microfiber and Pad detergent
I like Micro-Restore for stronger cleaning and Pinnacle or DP for general cleaning (leaves them a bit softer).
I have tried them but didn't see any magical results for the cost. I use no dye/fragrance detergent and add vinegar. The vinegar removes the hard water I have here in Florida. Seems to work pretty good and is very affordable.
I've tried Pinnacle, DP, and micro restore.
Pinnacle was my favorite but not by a large enough margin for me to care. Calculate the cost of each per wash and take the cheapest of the three. Don't forget to calculate the fact that some need more than others per wash.
I went through a gallon of DP and am currently in my gallon of MR. After this I think I might try what Porsche Pilot, Dark Horse, and others do.
:dancebanana:
Sky's the Limit Car Care
I do think, to get the near-magical results they show, you need to presoak in detergent for a couple of days - starting from the minute you are done with the MF.
Had some white MF gloves my buddy used to clean BMW wheels (only the gloves, no other MF - with waterless). Threw them in my soak bucket and washed with Micro-Restore. Came out almost new looking.
Thanks Guys! Keep them coming, how about dish washing liquids, can it do the job without harming our precious MF's?
I use woolite or similar, let them soak in bucket of warm water for a while then drain...dump sopping wet towels in machine another cap of woolite and wash.... cost about 1.50 a load for detergent, i will be trying a MF restore in a few more washes
If you have totally trashed a MF, scrub with Dawn Direct Foam and rinse with warm water before throwing in the soak bucket. Does a number on nasty, greasy crud. Does not get out all stains (I haven't found anything that does).
I use Charlie's liquid laundry soap, but I generally do a pre-soak in Snappy Clean or the DP pad cleaner to break up the LSP's, polishes, and dressings.
Different for each.
MF's=Micro-Restore
Pads=XMT Cleaner
By North1Star in forum Auto Detailing 101
Last Post: 01-02-2019, 11:44 PM
Last Post: 05-26-2018, 08:00 AM
By iStig in forum Auto Detailing Tools and Accessories
Last Post: 12-18-2017, 07:02 PM
By gatoman39 in forum Auto Detailing 101
Last Post: 07-24-2017, 01:42 PM
By Benzmeister in forum New Car Care Products
Last Post: 07-06-2006, 09:23 AM
