Air Compressor Strength
Hi guys
Don't know if this is the right place for this but does anyone know how strong an air compressor you need for cleaning DA microfiber discs? Getting my DA mf kit soon and need to get an air compressor.
Thanks,
Re: Air Compressor Strength
Hi Mike,
Compressors are capable of producing some very high and dangerous levels of air. Most air guns are designed to regulate the actual pressure delivered to about 30psi regardless what in the hose.
Depending on your needs you may be able to get by with one of the small portable units from one of the big home centers.
Many air tools will list its air consumption and if your goal is to use large amounts of air size the compressor with that in mind. Compressors are rated in CFM; cubic feet of air per minute at 40psi and 90psi. This should correlate to the tools you intend to use...
Any small compressor will work for pad cleaning. But think hard about if you are gunna want to buy some air tools in the future. Perhaps a tornador...
Agreed. However, I wouldn't go any smaller than a 3 gallon unless you want it running constantly.
The larger the tank, the more cleanings you can get before you hear the compressor again.
I limit my compressor to 30psi just in case. You don't need a lot of pressure to clean pads. This method of pad cleaning is really efficient and fast.
I have a Makita MAC700 and it is quiet and quite good at maintaining the pressure needed for many air tools.
I'd definitely recommend an oil-lube type compressor for long life and quietness.
I found a deal by monitoring the deals web sites. If you're not on a hurry, bookmark Slickdeals: The Best Deals, Coupons & Discounts on Laptops, Computers, LCDs, TVs, Dell, HP, Apple, Amazon and DealCatcher: Free Online Coupons Amazon, Dell, Old Navy, Overstock and check then daily. Sooner or later you may strike on one.
Wow, thanks guys for the speedy input!
Yeah I'm only looking to clean pads for the moment, air compressor's aren't cheap in my country so will look at something small and step up in future.
Thanks again to everyone and BobbyG for the detailed (excuse the pun) answer.
Originally Posted by Mike@DistinctImage
...air compressor's aren't cheap in my country so will look at something small and step up in future...
Just to be nosy, how much are compressors going for in Cape Town?
Bill
BillE, depending on size, but a 50 liter, 2.2kW (don't know what that is in imperial terms) is around R3000, so roughly $400.
Pretty expensive for us though. But I think I'll be good with a much smaller one for my purposes
Mike, just keep in mind that you don't HAVE to have/use an air compressor to clean the MF pads; you can use a pad brush or bug sponge as well if a compressor would be a major expense for you.
Thanx!
Is that $400 in 'your' money or 'mine'?
Like I said above, just curious and nosy...LOL
Here's the conversion for whomever wants it...50 liter=13.2 gal (US), 2.2KW=2.95HP
Bill
By Bobbykart in forum Auto Detailing 101
Last Post: 11-15-2013, 10:00 PM
By 05xrunner in forum Auto Detailing 101
Last Post: 07-26-2011, 10:02 AM
By shriram in forum Auto Detailing 101
Last Post: 02-24-2011, 01:13 AM
By mg6045 in forum Auto Detailing 101
Last Post: 01-04-2011, 10:03 PM
By Jenn1270 in forum Auto Detailing 101
Last Post: 01-01-2010, 03:48 PM
26 | 27 | 28 | 29 | 30 | 31 |
