Results 11 to 20 of 38
    Super Member Twister's Avatar
    May 2006
    Texas
    1,177
    Re: 1st "Documented" Metro MasterBlaster Catastrophe
    I've been wanting one but this worries me. Is it only coming in greased or is it breaking off?
    Super Member Scarelane's Avatar
    Apr 2011
    Otsego, MN
    375
    That sucks for sure, but a Catastrophe? Little bit dramatic I think.....
    My name is Ted and I'm a Auto Geek!!
  3. #13
    Super Member IID's Avatar
    Sep 2010
    Northwoods
    2,195
    Quote Originally Posted by Scarelane View Post
    I thought the nozzle tore from the hose!
    It seemed the ribbed profile of the hose was just that,when in fact it's also the thread profile as well.
    Wasn't trying to be fricken dramatic!
    Team Flex PE14-2 150(Serial#0005)/3401/3403/XFE 7-15
  4. #14
    Super Member Ron Atchison's Avatar
    May 2011
    Illinois
    1,034
    Use some silicone sealer/adhesive on it before you screw it back on, so if you ever need to take it off in the future you can. Glue may be a little to permanent.
  5. #15
    Sep 2010
    Northwoods
    2,195
    Quote Originally Posted by rzatch View Post
    I appreciate your advise (Thank You) and may take it into consideration but I can't think of a reason for the nozzle NOT to be attached to that part of the hose as there is another spot that clamps the two together.
    When the nozzle unscrewed from the hose,the air velocity/pressure clearly dropped from having no nozzle on the end of it.From stepping down from the hose I.D to the nozzle I.D/outlet,is where this unit really picks up huge air pressure.
  6. #16
    Super Member Audi X2's Avatar
    Oct 2010
    Naples, Florida
    1,239
    My MB did the same thing last week, but did not cause any damage.
    For the cost of this unit it should not have this issue.
    Buddy
  7. #17
    Super Member snowking724's Avatar
    Feb 2010
    Methuen
    724
    Quote Originally Posted by Audi X2 View Post
    In a sense, it's actually a feature. You have the option to swap attachments if needed, as well as replacing a possibly broken piece instead of the hose and all. With a little care and a quick check I don't see this being an issue.
    Famous last words of a redneck- "Hold my beer, watch this "
  8. #18
    Oct 2010
    Naples, Florida
    1,239
    Quote Originally Posted by snowking724 View Post
    I would agree if the system worked better for changing attachments. A feature should not cause failure in the middle of use without choosing to do so.
    I spend a great deal of time caring for my products thank you very much.
    Buddy
  9. #19
    Aug 2010
    New Jersey
    15,170
    My recollection is there was a little bit of glue from the factory. I got mine years ago, but I had to take the hose apart because I added an extension hose. As has been said, you need to keep an eye on these connections or add a drop of glue (as noted, a lot of glue might interfere with a future desire to disassemble).
  10. #20
    Super Member alko's Avatar
    May 2011
    4,342
    I got my Metro Vac n blow back in July. I have used it probably 4 times. I've already noticed the coupling separating from the hose. Not liking that, but I will try the mentioned solution if need be.
    Alex
    ...."Do the right thing...even when no one is looking"
  1. Metro Vac n blo "generic" extension hose option?
    By traubgator in forum Auto Detailing Tools and Accessories
    Last Post: 10-20-2016, 01:10 PM
  2. Metro MasterBlaster
    By lunchboxmunchy in forum Auto Detailing 101
    Last Post: 09-02-2013, 12:55 PM
  3. Metro MasterBlaster 8hp vs Leaf Blower
    By atoy in forum Auto Detailing Tools and Accessories
    Last Post: 11-30-2011, 07:07 PM
  4. Metro MasterBlaster 8.0 HP
    By Mobile detail in forum Products Guides
    Last Post: 07-15-2011, 03:58 PM
