Foamgun review
I used my new foamgun today for the first time and think it is an awesome
tool for presoaking and washing your car. I must say that I will have to
experiment with soaps and dilution ratios. I mixed Meguiars GC in a quart
mason jar 2 days ago as I have heard this aids the soap disolving into a
usable solution. I mixed it 4 to 1. I started on the lowest setting on the
foamgun and got soapy mix, I moved up to the max setting and here came
the thick foam. Wow! My truck was not real dirty so I just had a bucket to
rinse my mitt in. I got really good lubricity and like that when I put my
rinsed mitt back to the paint the solution just soaped up like I had taken
from a soapy wash bucket. I am eager to see Autogeeks new foamgun
soap. Until its release I will be trying different soaps and mix ratios and will
report back with my results. This is a heavy duty tool and should last a long time. I enjoyed using it. Another great tool by a great detailing supply
company, Autogeek!
I have found one ounce of soap and about 12 ounces of water is all that is needed for two cars in the foam gun. I keep the setting arm (small brass pin) at the lowest setting. I do have nice water pressure, but would think that adjusting this pin would be all that was necessary with slower water systems.
[QUOTE=killrwheels@autogeek]I have found one ounce of soap and about 12 ounces of water is all that is needed for two cars in the foam gun. I keep the setting arm (small brass pin) at the lowest setting. I do have nice water pressure, but would think that adjusting this pin would be all that was necessary with slower water systems.
What kind of soap were you using?
[QUOTE=belcherm58]
The one in the pic is the newest AG creation and not quite available for purchase. Prior I had tried several and found that Poorboys Suds did exactly what I wanted , I would highly suggest it as an alternative.
I mixed 1 cup Of Meguiars Gold Class wash soap with 3 cups of water making
1 quart of wash solution. I did not get a heavy foam until I moved the brass
pin to the max setting. I knew that the pictures that you submitted were of
the unreleased Autogeek formula. Are you saying that the Autogeek formula will be mixed 1 oz soap to 12 oz of water? I am concerned about the cost
of the soap formula to create the foam that I want. Using 1 cup being 8 oz
of the GC at $7.99 fot 64oz is a .99 cent solution for the quart. I used the
whole quart to foam the truck. I am eager to see the price of this new
formula by Autogeek. One soap that I am considering for foamgun use is
the Meguiars Hyper Wash. They claim a dilution ratio of 400 to 1. I will try it
and report my findings. The Hyper Wash is $29.99 per gallon at Autogeek.
I got no directions with my sample, so I winged it. Appeared to work well since we still had foam in the street almost an hour after finishing. I believe I used 2 ounces in that pic, and tailored my answer to the minimum. I hope it will be cost effective (ie. DP Line) and I hope it will come in larger sizes also. Using that much Megs Gold Class would worry me too ... you need to try some other soaps. I also had ok results with NXT (blue formula) but nowhere near Poorboys Suds nor this sample.
The Foam gun is the Bomb. I just got mine today and had to use it. It was even raining but when it stopped I pulled the car out and gave it wash. I never had so much fun washing, used PBSS and the foam was awesome. It made washing easier and a lot faster. My wife thinks I'm crazy, I guess I have to wash her van tomorrow.
By trhland in forum Auto Detailing 101
Last Post: 04-17-2007, 05:08 PM
By emaxxman in forum Auto Detailing Tools and Accessories
Last Post: 06-23-2006, 07:51 PM
By scooterguitar in forum Auto Detailing 101
Last Post: 06-17-2006, 04:06 PM
By bluzman in forum Auto Detailing 101
Last Post: 06-12-2006, 01:57 PM
By belcherm58 in forum Off-Topic
Last Post: 04-04-2006, 11:29 AM
