Foam Gun Newbie
I just used my quart size foam gun for the first time on Friday. At first I added the entire 2 oz. sample of DP Xtreme Foam soap and 8 oz. of water like the directions say. The 8 ounces of water didn't even fill the container up half way, but I figured I would proceed. So, I set the ratio adjuster to the maximum (far right) and let it rip! The contents in the container only lasted 2 minutes MAX! and I was a little disappointed.
Next, I decided I would try it out again. So, I added about 2 ounces of Poorboy's Super Slick & Sunds, but this time I filled the container up about 90% of the way with water. I also, set the ratio adjuster back 2 spots. This time it worked much better, and I was able to do a pre-soak on my car and also lead my sheepskin mit while washing my car for the entire wash process.
I am just a little baffled why when I followed the directions on the DP soap it only lasted for two minutes? Was I not suppose to set it to the most concentratred dillution ratio? Does anybody have any tips or suggestions for me being new at the Foam Gun? Thanks.
I haven't bought one yet, but I am sure some others will chime in... It sounds like the Max setting is best used for highly soiled areas, where the middle setting is for a normal wash?
I just add about 2-4 ounces of the DP soap to the canister and fill the rest with water. I set it on about 3 clicks and I get lots of foam and it lasts me the entire wash.
Super Moderator
Helps if you shake the canister every few mins. gets it foaming.
When I shake mine, it leaks out the air hole.
I noticed the same thing, so I just tried to swirl the solution around so that it wouldn't escape out the top.
By SON1C in forum Product Reviews
Last Post: 10-25-2014, 04:21 AM
By davidnolen in forum Auto Detailing 101
Last Post: 07-02-2014, 09:16 PM
By Speedjunkie in forum Ask your detailing questions!
Last Post: 08-03-2012, 04:07 PM
By Plan b Detail in forum Auto Detailing 101
Last Post: 08-03-2011, 11:13 PM
By wolfpacker92 in forum Auto Detailing 101
Last Post: 05-23-2007, 08:17 PM
