Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Super Member opie's Avatar
    Mar 2021
    Pa
    2,230
    Pad washer....worth it?
    Tired of soaking then hand cleaning of atleast 10-12 pads after a buff job. Are pad washers worth it to clean and speed up the process?
    Super Member JustJesus's Avatar
    Oct 2014
    Orange & LA Counties
    1,294
    Re: Pad washer....worth it?
    i bought one on sale and love it. It does save me time. My old process involved partial hand cleaning. It was failry time consuming. New process using the Lake Country pad cleaner saves me a good amount of time.
  3. Likes opie liked this post
  4. #3
    Aug 2015
    Andover, MN
    1,730
    I'll be honest in that I haven't used one, but I've always wondered how they wouldn't shorten the life of your pads considering you're rubbing them against a square grid.
    And then there's the corded tool with a bucket of water factor...
  5. Likes PaulMys, BudgetPlan1 liked this post
  6. #4
    Oct 2014
    1,294
    Quote Originally Posted by oneheadlite View Post
    The one i'm using isn't a square grid. It's "ribs" are rounded and quite smooth. With proper technique, i don't see the pads' life being shortened.
    I do tend to use my cordless polisher with it
    edit: to add to the "bucket full of water factor" - the LC unit is "enclosed" so it's not like you have an open source of water. In the pic below, I do have a bucket of solution for a pre rinse as I had several pads sitting while I waited for my unit to arrive. Normally, it would just be the LC pad cleaner. The cleaning solution from the pad cleaner would run down into a separate compartment below the center piece. So it's not like a "bucket of water" so to speak
  7. Thanks TTQ B4U, oneheadlite thanked for this post
    Likes DFB liked this post
  8. #5
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    Quote Originally Posted by JustJesus View Post
    I just ordered one of those today as I've been putting it off and using a more manual method. Thanks for confirming your thoughts on it.
    2023
  9. #6
    Oct 2014
    1,294
    Quote Originally Posted by TTQ B4U View Post
    You're welcome Pad washer....worth it?
  10. #7
    Oct 2014
    1,294
    Just to add, this is the best video i found (I watched several) on how to "best" use it.
  11. Thanks opie thanked for this post
    Likes PaulMys, DFB liked this post
  12. #8
    Mar 2021
    Pa
    2,230
    Hell yes thankyou for all that great info!! Im gonna order the lake country one as well. Also might as well take advantage of the 25 percent off.
    I always dreaded the pad cleaning part of the gig cuz it does take some time when you have many dirty pads.
  13. #9
    Aug 2015
    Andover, MN
    1,730
    Thank you for sharing! I've not seen that style, I think I've only seen ones like the Grit Guard style. That one had the more square edged grid that made me nervous.
    I suppose on the electricity front you could also just run a drill adapter (Griot's has a quick connect adapter that threads onto the DA backing plates for pretty cheap) and use a cordless drill. But like you mention, it looks like it's pretty contained.
  14. #10
    Sep 2020
    Eastern PA
    1,815
    Don't think I've watched that video. I'll check it out.
    I do have that pad washer. My one comment on it is that the latest version does not have a splash guard and I've gotten a little wet when spinning the pads dry. Might not want to use it by the vehicle. I was actually going to put a splash guard on one side of it.
    Oh, and don't forget a GFCI.
  1. Homemade undercarriage pvc washer for the non pressure washer.
    By ndsports in forum Auto and Garage Accessories
    Last Post: 02-04-2017, 03:09 PM
  2. Lake Country Pad Washer vs Universal Pad Washer?
    Last Post: 08-14-2016, 12:59 PM
  3. Grid Guard Pad Washer vs. Lake Country 3000d pad washer
    By fotomatt1 in forum Products Guides
    Last Post: 08-12-2016, 09:03 AM
  4. Opinions on clear bras. Worth it or not worth it?
    By AliMusa in forum Auto Detailing 101
    Last Post: 05-17-2013, 12:08 PM
  5. Replies: 6
    Last Post: 10-28-2011, 03:11 PM
Members who have read this thread: 6
