Page 6 of 13 FirstFirst 12345678910111213 LastLast
Results 51 to 60 of 130
  1. #51
    Dec 2018
    7,212
    Re: Rinseless wash sponges
    Did you pre-treat each panel, I'm guessing not since you only made 2 gallons of solution. I always pre-treat, ESPECIALLY something THAT dirty AND white. I also would've made the ratio stronger to get down and clean out that white AND so your drying towel didn't look like that.
    Using a RW sponge seems to keep more dirt in the solution on the car. No way around it your Drying towels are going to get dirty so I just use more towels to dry when I use the sponge.
  2. #52
    Feb 2012
    Palatine Illinois, USA
    24,668
    On a real dirty car like that Tacoma pre-treating is a MUST, using alot of solution too. Additionally dunking the sponge in the rinse bucket MORE OFTEN is key. The sponge holds alot of solution and dirt, so more frequent dunk and rinses are important.
    The GD method is also an option for everyone as wellRinseless wash sponges
    2022 Elantra N Cyber Gray
  3. #53
    Nov 2015
    Los Angeles, California
    13,806
    Yes I did pre treat/pre spray. I always have a 1.5L Kwazar pump sprayer that’s full of N-914 available for things like this, along with keeping a full gallon diluted @1:128 to refill it.
    I thought about using more than 1oz. in the bucket but hey the bottle says rinseless wash @ 1:256 so I took their word for it and surprisingly it managed to work good enough to where I’ve got no complaints with its performance. Would it have worked a bit better @1:128 for this situation? Probably.
    I noticed the drying towel took a big hit when I used it to dry the windshield, you know how along the top of the windshield you’ve got that part where the rubber meets the paint? Yea that’s usually a spot that ruins a drying towel on a vehicle this dirty, and that’s with me bearly even touching that area.
    I cleaned the plastic on the rear bumper with the sponge, but didn’t even attempt to dry that plastic with my drying towel after what had happened on the windshield. Lol.
    Also, in order to try and get it as clean as possible I went over each panel once with 1 side of the sponge, then flipped to the other for another pass, then dunked the sponge in the rinse bucket, and came back to hit the panel one last time before wiping it with my drying towel and finally fipping my drying towel for the final dry wipe.
  4. Thanks Klasse Act thanked for this post
    Likes Klasse Act liked this post
  5. #54
    May 2007
    680
    You gent's have got a much bigger -set- that I do
    I only do RW/WW on door jams, trunk jambs and basically panels with PPF film on them.
    I can't muster to use it on paint panels.
    I need water and lots of it.....
  6. Thanks Eldorado2k thanked for this post
    Likes DFB liked this post
  7. #55
    Nov 2015
    13,806
    Quote Originally Posted by chefwong View Post
    Wow that’s actually a great idea that I’ve never even thought of… Dealing with dirty trunk & door jambs can be a PITA especially the trunk jambs when you’ve got a hose nozzle trying to not get things in the trunk all wet. The BRS and a bucket of rinseless would be clutch for that. Thanks for the tip.
  8. Thanks Klasse Act thanked for this post
    Likes Klasse Act, MisterSnoop, DFB liked this post
  9. #56
    May 2007
    680
    Wow. Goes to show - a different angle on how one approaches things....
    On this 6 page count thread, I would never consider it on paint panels
  10. Thanks Klasse Act thanked for this post
  11. #57
    Mar 2017
    Southeastern PA
    2,480
    Back when I used Wolfgang Uber for rinseless, my BRS would also get dirty/stained. After switching to N-914 it cleaned the BRS and it looks brand new again. I had purchased another BRS expecting to replace it but that one is still in the package due to how N-914 keeps mine looking great.
    Bruno Soares
  12. Likes Eldorado2k, dgage liked this post
  13. #58
    Dec 2018
    7,212
    That’s literally what it was made for. It scared me at first but I tried it for a while and it works.
  14. #59
    SELF BANNED
    Jun 2019
    1,076
    I watched a video earlier on youtube by Eddie Colon - funny guy - he demonstrated a big difference in how DIY left the towel clean comparable to absolute after soaking for a while. It was interesting.
  15. #60
    Super Member DFB's Avatar
    Aug 2019
    Australia
    3,233
    That's what I started using rinse-less/water-less products for too, door jambs, engine bays ect.
    While I still feel safer using lots of soap and lots of water, I'm slowly gaining confidence in rinse-less for paint.
    I think the key with rinse-less is thinking on your feet, as in don't just treat every wash the same or follow a set routine. Sometimes you will need more pre-soak, sometimes you will need to use more towels or more frequent dunking, sometimes you may need to pre-rinse the certain areas, sometimes you only need the basics.
  16. Thanks Klasse Act thanked for this post
    Likes oneheadlite, Klasse Act liked this post
  1. Replies: 6
    Last Post: 12-15-2020, 02:07 PM
  2. Recommendations for sponges to wash with
    By prr in forum Auto Detailing 101
    Last Post: 01-19-2016, 10:42 AM
  3. MF Sponges - Do you wash before 1st Use?
    By spewking in forum Auto Detailing 101
    Last Post: 09-27-2015, 06:34 AM
  4. Replies: 1
    Last Post: 03-10-2012, 09:34 PM
  5. How to clean sponges after a wash
    Last Post: 07-06-2011, 07:42 AM
Members who have read this thread: 8
