Re: Wheel/tire detailing roller stand....recommendations?
Originally Posted by chefwong
DFB, With that itty bitty plastic table, is it secure enough to not wanna fall flat with a 22/23 inch wheel assembly ?
Or is there makeshift screws on frame to table I'm not seeing.
Obviously have to experience it 1st person, but I would be thinking a wheel assembly on a table setup like that....the weight of the wheel would still rock the roller stand ?
Yeah, don't use a blow molded plastic table from the hardware store like I did. It's just too narrow and too light to be a viable solution, especially on Swisstrax. I really need to look into a more stable solution for this.
Heh, you had me do a double take
I just put mine together. Even without a wheel, the VERT piece is very top heavy and even just a slight pressure will want to make the entire thing tip.
I think a commercial kitchen cart would be perfect for this (depending how thick the SS top is), it should be thick enough to also drill a hole to mount the stand to it
And given its SS, it's perfect given the use case - aka, lotsa chems and liquids being thrown at it. The smaller the better - it just needs to be large enough to serve as a rolling SS cart IMO
I've been thinking about this subject every since you brought it up.
I'm currently looking at something like this, a folding work bench...................
https://www.amazon.com.au/Stanley-Fo...8afe5d466&th=1
Size wise, it should be fine, and should also allow you to clamp the wheel stand down if needed. It's being plastic means I could wash or use chemicals on it without destroying a steal or wooden bench.
Thoughts?
By Justin at Final Inspection in forum Product Reviews
Last Post: 03-01-2016, 09:49 AM
By Lustrous Detail in forum Auto Detailing 101
Last Post: 09-18-2015, 05:48 PM
By Skoob in forum Auto Detailing 101
Last Post: 03-02-2015, 08:08 AM
By icepickjazz in forum Auto Detailing 101
Last Post: 03-27-2013, 02:19 PM
Members who have read this thread: 16
- John U,
- brianshaeffer,
- Woob,
- barryscott,
- Karl_in_Chicago,
- bill walsh,
- BillyJack,
- Setec Astronomy,
- grovlet,
- RZJZA80,
- Desertnate,
- M0E7,
- SNP209,
- DFB,
- Icarus,
- Silly Rabbit
26 | 27 | 28 | 29 | 30 | 31 |
