Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. #21
    Super Member DFB's Avatar
    Aug 2019
    Australia
    3,169
    Re: Wheel/tire detailing roller stand....recommendations?
    Quote Originally Posted by chefwong View Post
    DFB, With that itty bitty plastic table, is it secure enough to not wanna fall flat with a 22/23 inch wheel assembly ?
    Or is there makeshift screws on frame to table I'm not seeing.
    Obviously have to experience it 1st person, but I would be thinking a wheel assembly on a table setup like that....the weight of the wheel would still rock the roller stand ?
    Yeah, don't use a blow molded plastic table from the hardware store like I did. It's just too narrow and too light to be a viable solution, especially on Swisstrax. I really need to look into a more stable solution for this.
  2. #22
    May 2007
    668
    Heh, you had me do a double take
    I just put mine together. Even without a wheel, the VERT piece is very top heavy and even just a slight pressure will want to make the entire thing tip.
    I think a commercial kitchen cart would be perfect for this (depending how thick the SS top is), it should be thick enough to also drill a hole to mount the stand to it
    And given its SS, it's perfect given the use case - aka, lotsa chems and liquids being thrown at it. The smaller the better - it just needs to be large enough to serve as a rolling SS cart IMO
  3. #23
    Aug 2019
    Australia
    3,169
    I've been thinking about this subject every since you brought it up.
    I'm currently looking at something like this, a folding work bench...................
    https://www.amazon.com.au/Stanley-Fo...8afe5d466&th=1
    Size wise, it should be fine, and should also allow you to clamp the wheel stand down if needed. It's being plastic means I could wash or use chemicals on it without destroying a steal or wooden bench.
    Thoughts?
  1. Replies: 7
    Last Post: 03-01-2016, 09:49 AM
  2. 'Must Haves' for Wheel/Tire/Wheel Well detailing
    By Lustrous Detail in forum Auto Detailing 101
    Last Post: 09-18-2015, 05:48 PM
  3. Winter detailing. I can't stand it!
    By Skoob in forum Auto Detailing 101
    Last Post: 03-02-2015, 08:08 AM
  4. Newbie -- Tire & Wheel Care Product Recommendations
    By icepickjazz in forum Auto Detailing 101
    Last Post: 03-27-2013, 02:19 PM
Members who have read this thread: 36
