Results 1 to 10 of 10
    Aug 2018
    124
    As a newbie polisher could I get away with just having the Makita PO6000C 6” pad.
    I am still trying to find a 3” backing Pad that I can fit on, or adapt to attach to my PO6000C.
    not having much joy!
    I saw a video with Kevin Brown using a 6” DA, and he did have at one stage only part of the pad, on some small sections.
    Obviously KB is probably imo a genius level polisher.
    But could I as a first timer, get away with just having say 1/4 of the Pad flat on some small sections?
    The sort of areas I want to do are highlighted in this pic of my front bumper, with red highlighter arrows
    So one might have 1/4 of the pad on the narrow section.
    Alternatively I did see a Flex 8-4 80 with a 3” backing pad, thats reasonable at ฃ149.
    but I was a tad concerned; as its a rotary, not a “newbie-safe” DA. And its lowest speed is 1,350 ... I would have felt safer if it went down to 700rpm
    I am not doing any compounding just final finishing with 3M Ultrafina SE, and the blue Ultrafina Pad.
    Attached Thumbnails Attached Thumbnails -f219f9b5-3cce-469f-9276-9a3b1b1bfbcb-jpg
    Nov 2016
    KY
    1,065
    Re: As a newbie polisher could I get away with just having the Makita PO6000C 6” pad.
    Best plan would be get a Griot's or even a Porter Cable DA with a 3" backing plate.
    Kirk Harrod's Mobile Detailing, Frankfort, KY
    Official Detailer of Camarofest 8 & 9
    No one has detailed more Camaros.
  3. Likes Submariner liked this post
  4. #3
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    For those small areas you can also buy attachments(backing plate) for a cordless drill, a few small pads and buff it that way. Saves a lot of looking for backing plates that don’t exist for your Makita polisher.
    Jim
  5. Likes SWETM liked this post
  6. #4
    Newbie Member Black Lab's Avatar
    Oct 2016
    South of Chicago
    Newbie? No compounding? Limited on tools? I'll just throw out the suggestion of doing those areas by hand. Heck, I've got 5 polishers and still do areas like the air dam in the pic you posted by hand. Not often, but for a quick polish... everyone needs a little carpal tunnel to tell their friends about, right?
  7. Likes dlc95, Submariner liked this post
  8. #5
    Aug 2018
    124
    Quote Originally Posted by KirkH View Post
    Thanks
    Sadly We pay a lot more in the UK ...
  9. #6
    Aug 2010
    Fairmont, MN
    3,189
    As "Black Lab" said above, I'd be doing those itty bitty areas by hand. Sometimes the 'old fashioned way' is the easiest and quickest.
    Good luck...
    Bill
  10. #7
    Aug 2018
    124
    Quote Originally Posted by BillE View Post
    Good luck...
    Bill
    Thanks
    Luckily Mike checked for me that ine can use the Flex 75mm mini backing pad.
    So I have ordered one of those.
    And any difficult areas Ill do by hand
  11. #8
    Aug 2018
    124
    Quote Originally Posted by Dr Oldz View Post
    Thanks I found a set, and could use my right angle mini drill.
    Mike very kindly found out for me that the Flex mini backing pad fits.
    So I will try that and hope the Makita is not too big.
    If it is I could try that set, with the mini drill.
    Just a bit worried as its been used on some wood beams , and has a Ventilation system designed to blast air at the drilling hole, so in my case on the back of the backing pad.
    Lets hope their isnt any wood dust inside the machine that could be blasted onto the panel. Will need a serious clean to avoid that.
  12. #9
    Super Member RippyD's Avatar
    Jan 2016
    Portland, OR
    1,248
    Given that it's been used on wood I'd take the time to clean it as well as possible. Maybe run some compressed air through the vents, then run it, then compressed air the other way through the vents, run it, and keep going until there's no more dust. Obviously remove any visible sawdust with brushes, vacuum, or whatever. I would be inclined to disassemble and clean it it's not under warranty. You of course would need to be comfortable doing so.
    The common complaint I've seen about this machine is that it stalls easily in free-spinning mode. I think many people consider it a forced rotation machine only based on the free-spinning performance.
    2006 LR3 White // 2014 Boxster Agate Gray // 2012 Sentra Aspen White
    Sealant test resultsxxxxxDilution ratio chartxxxxxWheel cleaner info
  13. #10
    Aug 2018
    124
    Quote Originally Posted by RippyD View Post
    Thanks that was pretty much my envisaged cleaning route.
    But if the Flex mini backing pad works the I may just get by using it on the Makita.
    I saw those “stalling” issues comments.
    What I find odd is everyones goal seems to be , that it must spin .... so why not then just put it in forced mode?
    Other thsn in free spinning mode, it offers the protection not to burn off an edge because it wouls stall.
  1. Just got my Makita PO6000C 6” Polisher ... and a few questions ...
    By Submariner in forum Auto Detailing Tools and Accessories
    Last Post: 10-04-2018, 04:50 AM
  2. Replies: 27
    Last Post: 09-17-2018, 05:46 PM
  3. Replies: 5
    Last Post: 09-06-2018, 04:39 PM
  4. Makita Da Polisher
    By ElDetailer in forum Auto Detailing 101
    Last Post: 04-30-2018, 11:36 AM
  5. Makita polisher
    By Jet Black in forum Auto Detailing 101
    Last Post: 05-26-2014, 03:18 AM
