Page 1 of 2 12 LastLast
Results 1 to 10 of 19
    Jun 2017
    187
    4" backing plate??
    I picked up some 5" Hybrid Power Finish pads on BOGO and they need a 4" backing plate. I tried my 3" but the pads flex too much on such a small backing plate. Any suggestions for finding a 4" backing plate for a GG6? I have seen a few DA 3 1/2" backing plates, but no DA 4". I might have to do a 4" rotary backing plate with an adapter.
    Thanks!
    Super Member DaveT435's Avatar
    Jun 2012
    Arlington Texas
    3,982
    Re: 4" backing plate??
    I know there is a 4" rotary backing plate. You can get an adapter. I think that pad was kind of designed for the 3401 and their 4" backing plate.
    2015 F-150 Crew Cab Lariat
    2016 Chevrolet Camaro 2SS
  3. Thanks wgasa84 thanked for this post
  4. #3
    Super Member Rsurfer's Avatar
    Jan 2007
    14,112
    Most 5" backing plates are just under 5" (4 7/8").
  5. #4
    Jun 2017
    187
    I tried my 5" bp... No dice
  6. #5
    Jan 2007
    14,112
    Dave is right about the 4" bp for the 3401. You might be better off with 5" pads as they are a standard size.
  7. #6
    Jun 2017
    187
    I might try the rotary BP with an adapter. I have a good number of those pads.
  8. #7
    Jan 2007
    14,112
    Quote Originally Posted by wgasa84 View Post
    I don't blame you if you have a lot of pads. I just don't trust those adapters.
  9. #8
    Jun 2017
    187
    Red Locktite at the BP/adapter! If it comes loose after that, I'm doing something wrong.
  10. #9
    Jan 2007
    14,112
    It's not that, it's the 3/16" shaft.
  11. #10
    Super Member RippyD's Avatar
    Jan 2016
    Portland, OR
    1,253
    I use this 3.5 BP" with 4" pads. Works fine.
    2006 LR3 White // 2014 Boxster Agate Gray // 2012 Sentra Aspen White
    Sealant test resultsxxxxxDilution ratio chartxxxxxWheel cleaner info
  1. Replies: 19
    Last Post: 05-31-2020, 02:42 AM
  2. Megs 5" backing plate "WASHER"
    Last Post: 03-03-2016, 11:43 AM
  3. Any downside to using 3"/3.5" backing plate & pads on 6" DA
    By dennis hiip in forum Auto Detailing 101
    Last Post: 09-16-2014, 05:01 PM
  4. Griots 6" backing plate VS. Lake Country's backing plate
    By ryanmcg1 in forum Product Reviews
    Last Post: 09-29-2011, 11:29 PM
  5. Meg's 3" Sanding backing plate w/ "Air Holes"
    By Mindflux in forum Wet-Sanding, Cutting & Buffing
    Last Post: 06-09-2010, 11:48 AM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
