Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Junior Member Edi25's Avatar
    May 2017
    79
    Recommendation for wool pad on a DA
    Pretty much not getting enough cut on my flex 3401 I need something heavier I'm looking for wool pad to pair it up with I have in hand the factory backing plate and 4inch backing plate
    Thanks !
    Super Member LEDetailing's Avatar
    Jan 2016
    Wisconsin
    1,729
    Re: Recommendation for wool pad on a DA
    Have you tried microfiber cutting pads? I am amazed at the level of cut with MF pads and my Rupes 15.
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    Honestly wool doesn’t play well with a “DA” style machine IME. I feel wool is meant for a rotary style machine. There are some specialized wool pad for da machines but I have no experience with them. Perhaps post what you are working on and trying to accomplish so you can get some refined suggestions. The 3401 is a powerful machine and with the right foam pad and mechanical abrasive can pretty much handle anything.
    Jim
    Super Member VISITOR's Avatar
    May 2007
    9,730
    maybe lawrenceSA will chime in, there's quite a few of his write-ups where he uses a wool pad on his flex 3401...
    SELF BANNED
    Sep 2017
    570
    The 3401 doesn’t quite match the cutting power of todays long throw polishers. I was in the same boat, trying everything to get both my 3401’s to perform better. Your best bet would be the LC Blue foamed wool and LC Force Grey pad along with something like Scholl Concepts S2 Orange, Menzerna 300, Mothers HD Rubbing Compound etc.
    Super Member brettS4's Avatar
    Jan 2015
    Wisconsin
    649
    I don't have a Flex 3401 but I get excellent results on my GG6 with LC thin foamed wool pads.
    Just to chime in...
    When I need more cut and don't want to use a rotary, I throw a traditional rotary buffer wool pad on my FLEX and go to town...
    The fibers of a wool pad on a gear-driven orbital polisher are going to micro-mar the paint but that's the trade-off for MORE cut from this type of tool.
    Here's a full write-up where I shared this...
    How to restore a Barn Find - 1969 Ford Thunderbird - #7 Rub Out + FLEX = 3D products
    7.5" Lake Country Wool Pad on a FLEX 3401
    Before
    After
    There is so much how-to information in this write-up. I could turn it into a how-to book.
    Try to find this much info in a FB post...
    Here's another example...
    Just SONAX Cut Max with a wool pad on a FLEX 3401 - 1940 Pontiac 5-Window Coupe
    The paint on this old 2-door Pontiac was SO HARD and the scratches were SO DEEP that a foam cutting pad was just making them shiny. So I switched to wool on the FLEX 3401
    This is an aggressive compound using top notch abrasive technology and this is what I'm talking about when I say it's all about the abrasive technology.
    Next up... SONAX Cut & Finish with a LC Hybrid foam polishing pad on the FLEX 3401.
    On Autogeek.com
    SONAX CutMax Cutting Compound 1000 ml --> In the pictures
    SONAX CutMax Cutting Compound 250 ml
    6.5 inch 50/50 Wool Acrylic Polishing Pad
    6.5 inch 50/50 Wool Acrylic Polishing Pad - 3 Pack
    Flex XC 3401 VRG Dual Action Orbital Polisher
    The most valuable real-estate on a book is the front cover. It can be used to telegraph a message...
  10. #10
    For a Porter Cable, I'd go with any of the brands we sell for microfiber pads and a great compound.
    The THIN PFW's work too, here's an example.
    Pictures: 16' Key Largo Center Console Boat Detailing Class with Marine 31
    Million ways to skin a cat... (sorry PETA)
  1. Replies: 9
    Last Post: 11-02-2017, 08:31 PM
  2. foam backing wool or standard wool pad? (for rotary)
    By sansa in forum Auto Detailing 101
    Last Post: 02-24-2016, 12:48 PM
  3. Wool pad vs foam wool pad
    By surajprasade in forum Ask your detailing questions!
    Last Post: 07-03-2014, 02:01 AM
  4. Whats the difference in Wool pads and Foamed Wool pads?
    Last Post: 08-29-2012, 10:40 PM
  5. Lake Country Wool-Ball 3 inch & 5 inch Wool Polishing Balls
    Last Post: 11-09-2007, 10:20 PM
