Car polishing
Hello sir i have das 6 DA polisher and carpro fixer.wic foam pad is good for those items???
Pad choosing
Hello sir,
i have GG 6" and carpro fixer.
wic pad is good for above both items??
plz help me
Pad
Hello sir,
i have GG 6" and carpro fixer, sonus paint cleaner, Poorboys black hole glaze
plz help me
Re: Pad choosing
Fixer works great with a medium cutting foam pad. It also corrects very well with Microfiber pads; although, it can leave substantial marring that will require a finishing polish to refine. With the right foam pad it can finish down flawlessly on certain paint systems. Best solution is to perform a test spot with a variety of pads to see which offers the best balance of cutting and finishing ability.
Re: Pad choosing
Will marr with a DA, not so much with a Rotary.
Re: Pad choosing
Use a different product and avoid all the extra work and headaches .Hd speed micro cutting pad works great.
Re: Car polishing
Technically if you're going to use a dual action polisher with CarPro Fixer then you would normally be trying to remove swirls, scratches, water spots and oxidation as Fixer is a compound. So for your DAS6 DA Polisher I'd recommend getting some foam cutting and foam polishing pads and then do some testing to see which pad is giving you the best defect removal results on the paint you're working on.
My strong recommendation would also be to get as follow-up polish to follow the Fixer step because in my experience Fixer needs a follow-up step in order for the paint to look good.
Re: Car polishing
In which follow up product i want to use after done with fixer???
Re: Car polishing
But i have sonus paintwork cleaner and black hole glaze .
Above follow up product is enough after done with fixer???
Plz help me
By Joe@NextLevelDetail in forum Auto Detailing 101
Last Post: 06-26-2019, 06:14 AM
Last Post: 08-01-2017, 08:00 PM
By Themikerobe in forum Auto Detailing 101
Last Post: 04-24-2017, 02:59 PM
By Crispy in forum How to Articles
Last Post: 03-13-2015, 03:43 PM
By Justin in forum Auto Detailing 101
Last Post: 07-19-2008, 07:30 AM
