Looking to upgrade from Gilmour foam gun to pw/foam cannon
Realistically, what's the least amount of money I can spend on a power washer (preferably electric, not gas) and foam cannon while still getting at least decent results (I want it to be a good enough upgrade over my foam gun, but doesn't have to be the best pw/cannon combo available).
Please let me know specifics regarding make & model of pw and cannon, and if any special attachments need to be purchased as well.
I don't mind ordering online or going to HD/Lowe's/Sears...
Thanks!
Re: Looking to upgrade from Gilmour foam gun to pw/foam cannon
$99 power washer from HD or lowes w/Hd's foam lance($14)
irfan
laughing is the cure for all!
jeepgarage.org
Wow, that's not so bad at all (and not much more than my $40 foam gun). I always thought power washers were a couple of hundred + a good foam cannon was another $100 or so.
Does the $99 HD washer and lance provide good foam (that really sticks to the car) vs. the foam gun which tends to just run off?
Thanks again!
yeah i remember seeing a video and it did a good job. do a search and you'll find it. i forgot where it was
irfan
jeepgarage.org
I'll take a look for the video.
Any thoughts on which of these (Product Comparison Page) may be better (probably the $135 one that's on sale for $99)? Do I need to make sure I have a certain psi or flow rate?
Thank you again!
Hmm.. the $135 one (on sale for $99) seems only have a 20 inch hose vs. over 200 inches for the others.
amazon has a karcher 1600 psi for 99 as well
irfan
jeepgarage.org
I have the green wise one and the green wise foam lance from HD. Works well, foam is dependent on shampoo as well so get ready to use decent shampoo and it uses quite a bit more of it. I only use it when the car is really dirty otherwise it's a tradintional 2BM wash. Just easier to setup and I wash early in the morning anyhow.
Thanks!
Lowes has this model-
Shop Greenworks 1700 PSI 1.4 GPM Electric Pressure Washer at Lowes.com
For $179.99 but if you use coupon code CLEANGREEN you get $60.00 off.
The reviews are good and it is wheeled as well.
Gotta love the built in hose reel too!
Might be worth a look for $119.00
Jeff
Thanks for the further info and coupon code! Some of the ones on HD get really bad reviews. I see that the Lowes one is well-liked as you mentioned.
Anybody know off-hand if the HD cannon is compatible with the Lowe's washer? Or if not, is it usually just a matter of buying a cheap connector?
By JMak97008 in forum Auto Detailing 101
Last Post: 11-14-2017, 10:52 AM
By SON1C in forum Product Reviews
Last Post: 05-30-2016, 02:44 AM
Last Post: 10-25-2014, 04:21 AM
Last Post: 03-15-2014, 01:33 PM
By mc4nam in forum Auto Detailing 101
Last Post: 02-01-2014, 06:53 PM
