I have an older Mytee Lite II 8070 hot water extractor and it worked fine last year. Started it up this year and can not get hot water. The switch doesn't even illuminate (pretty certain that it use to if memory serves me right). So before buying a new $200 heater element from Mytee I want to make sure it is bad. I hear a common fix is to hit the "heater reset button", but for the life of me I can not find it! Could someone PLEASE point me in the right direction?
It's more than likely your heater rocker switch (simple cheap fix). They go out quite often. The reset button is on the thermostat which is located on the side of your heater. White thermostat with a button in the middle. I'm currently switching all my thermostats over to the automatic ones. The heating elements on these rarely go out, it's usually the switch or thermostat.
