Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Sep 2015
    Which Lake Country Pad?
    I'm looking to do some hand application of HD Speed since I won't have the opportunity to use my DA for another couple of months. Which Lake Country pad would be best for light swirl correction by hand with a hand applicator that holds 4" pads? I know what the descriptions say but I'm assuming that's with a DA, I'm either going to get a couple of white pads or if necessary the orange pads.
    Thanks.
    2016 VW Golf Sportwagen S - Tungsten Silver
    2016 VW Jetta S w. Tech. - Cardinal Red Metallic
    Aug 2010
    New Jersey
    15,378
    Re: Which Lake Country Pad?
    Why don't you get both? I guess if you are doing your white car I'd use the orange, and on your black car the white.
    Sep 2015
    I was leaning towards the white pad since it will be on my Sonata and the swirls aren't bad. It sounds like that may be the best choice for this situation. I'll usually use the DA for an AIO correction but I won't have access to it for a while so i don't want to spend too much on a one time application.
    Thanks.
    Aug 2010
    New Jersey
    15,378
    Honestly, you're not going to be able to do any swirl correction by hand unless you have a huge amount of time or huge muscles and a lot of Gatorade (or unless you just have one small spot that needs correction, in which case something like Meg's Ultimate Compound or Wolfgang Uber or Menz FG400 might be indicated, for hand use).
    I'd concentrate on getting the paint clean with your hand application.
    Junior Member zx10r Elle's Avatar
    Feb 2016
    82
    SonataLF,
    This is just my take on the situation; to make any headway I think you will want an orange pad, especially hand polishing an entire car. And for any decent finishing I think you will need the white pad.
    Since you are relying on HDSpeed which is designed for machine application I would think you'd work your arm off using just white pads, or even the orange but the orange may be more effective.
    Steve
    May 2014
    Northern Vermont
    1,400
    If you want it to look better why not just use a glaze & seal it until you can get access to your PC.
    Sep 2015
    It sounds like I'll just have to save the HD Speed for the DA. Maybe I'll just use the White wax by hand for now to hold me off until I can use the DA as I have been able to get some minor correction with Black Wax by hand in the past and White Wax is stronger.
    Aug 2010
    New Jersey
    15,378
    I think you were probably getting filling with those products.
    Sep 2015
    AFAIK There are no fillers in Meguiar's White and Black waxes. I wasn't able to totally remove the swirls until I applied with a DA but I was able to get minor correction by hand.
  10. #10
    Aug 2010
    New Jersey
    15,378
    Quote Originally Posted by SonataLF View Post
    Waxes are fillers.
  1. Replies: 28
    Last Post: 02-26-2022, 08:11 AM
  2. Lake Country Pad help!
    Last Post: 04-25-2015, 01:06 AM
  3. lake country or ?
    By chachi94 in forum Auto Detailing 101
    Last Post: 02-11-2015, 11:26 PM
  4. Which Lake Country Pad?
    By mdgrwl in forum Auto Detailing 101
    Last Post: 02-24-2014, 10:22 AM
  5. According to Lake Country...
    Last Post: 02-05-2010, 01:10 PM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
