Best advice for polishing and coating my truck
Ok, so I have a couple of threads already relating to my headlights and what order for the process of detailing combining paint correction and trim. This question is different from them.
I want to work my truck over but I am not going to get into extreme detail. I just want to make it look as good as practical. It is my DD and stays outside 24/7. The hood has a multitude of crows feet and the clear coat has failed on the right rear panel. There is a spot of about 12 inches in diameter where the clear has flaked off.
I know there is some discussion as to what one-step correction is. There seems to be a couple of different ideas on the so let me just tell you what I would like to do. I would like to use one-step to polish the paint and then I will wax/or seal it. I am going with wax right now (probably 845) but that can always change.
So my question is what materials would some of you recommend to polish it out in one step to get the most done without having to do another step? The paint has lots of swirls and some scratches, but that is mostly on top of the door where a brach rubbed in winds one day before I cut it off. I have seen a video that CG did where they used their V36 with one-step correction and then waxed it. I will say that I would like to use a product that has good work time and little/no dusting.
Re: Best advice for polishing and coating my truck
Most of us will tell you to do a test spot to see what works. In all honesty each vehicle is different.
I would not recommend V36. From your description, it sounds like you may have a few major scratches. A product which is in the similar price range but with better reputation would be HD Adapt. Try that with a medium cut pad of your choice. There isn't one answer for your situation.
Do you currently own any products?
And thank you for spelling it advice and not advise.
Those tree branch scratches are fairly deep. If that truck came to me, I would use M100 or Menzerna Fg400. Fg400 can work for a good amount of time.
If you decide to use what you already have, you can try misting the panel with a pad primer solution. That may help with the dusting.
I have been thinking about the FG400. I have also heard good things about HD ADAPT. You think I should use an orange pad for that? Also,how would you handle the area with no clear coat?
If you are looking for a good one stuff I use Menzerna 3 in 1 and it has amazing results. If you want a little bit more longevity you can go ahead and top it with Collinite 845
Personally my opinion only would be just to clean it up,give it a good wash and wax.There is no solo one step that will give you favorable results.That truck needs serious work.some rotary work is in order for that paint along with some cutting compound and polish.
Agreed
As I said, I am not looking to try and make it a show truck. It couldn't happen anyways without being repainted, especially with the crows feet and failed clear coat. That said, not doing anything but a wash and a wax is crazy. I can do a lot with going over it with the right polish and pad. The best advice of not doing anything isn't going to work. I don't expect to get out those big scratched but I can make it look better.
Is there anyway to make the area that has lost clear coat shine a bit? Would it be worth it to sand the edges and give it a spray of clear coat just to add some sort of protection?
I did that on my daughters beater car and it came out better looking than leaving the missing clear section. I am no painter but some simple, basic principles of cleaning well, sanding out a bit and multiple layers of rattle can clear dressed it up.
By Chet S in forum Auto Detailing 101
Last Post: 09-02-2020, 06:38 AM
By Tonykarter in forum Ask your detailing questions!
Last Post: 01-20-2019, 04:16 PM
By Based in forum Auto Detailing 101
Last Post: 10-06-2015, 01:12 PM
By spaceblues in forum Auto Detailing 101
Last Post: 08-15-2014, 05:41 PM
By vernh59 in forum Ask your detailing questions!
Last Post: 05-03-2013, 11:04 AM
