CQuartz DLUX & CarPro Reload
Hello guys,
I'm getting my rims (Vw Austin) polished to remove some of the minor scratches in the clear coat and they will also be putting CarPro Reload on my rims. Now I'm wondering when I get the rims back would there be any issues with me applying CQuartz DLUX over the same surface right away?
From what I was reading they say it should be in the other order however that wont be the case here.
Any ideas/suggestions?
Thanks
Re: CQuartz DLUX & CarPro Reload
you'd want to do that in reverse. Dlux is a coating, Relaod is a sealant.
I wish I could however the person who is detailing my rims has already done it.
But do you see any issue of me doing it in the other order? I'll probably buy a kit that has both so it would be like this.
Layer 1 - Reload
Layer 2 - DLUX
Layer 3 - Reload
It should still protect and be shiny/glossy correct? Nothing bad about doing it this way?
Thanks
nop do like mat say....
Sent from my iPhone 6 S using Tapatalk
you will just be waisting product. the reload will wear off faster than the Dlux causting the Dlux to come off with it.
at this point just reapply reload as needed (during regular washed), or let the reload wear off and apply Dlux.
Thanks,
Roughly how long do you think the Reload would take to wear off in the summer months?
Or is there an easy way to remove it?
Thanks
use car pro easer or apc clear
Originally Posted by bryanviper
Thanks,
Thanks
If it's Reload 2014 it takes some work to get it off, there is a video showing how it holds up. after 6 washes with APC it was still beading water off. Best way is to polish it off, or drive for a a few months and let the heat of the wheels wear it off.
is it new formula?its up 6 month. older formula wos 3 or 4 month?
Use a polish like reflect and a med cut pad to remove the reload then properly apply dLux.
By papnurgel in forum Auto Detailing 101
Last Post: 08-01-2020, 08:28 AM
By dogga85 in forum Auto Detailing 101
Last Post: 06-04-2020, 07:39 PM
By Midnite8 in forum Auto Detailing 101
Last Post: 05-02-2016, 09:31 PM
By BobbyG in forum Product Reviews
Last Post: 01-12-2016, 05:14 AM
Last Post: 06-05-2014, 06:29 AM
